Gen4 armour advice
- Thank you received: 2004
12 Nov 2026 07:24 #265549
Gen4 armour advice was created by Lambert
I'm conscious that my main working jimny is not now nor is particularly ever likely to be the tallest jimny ever. So consequently I have some ambition towards protecting the under side especially the transfer box, to that end I have found a full skid that picks up on the 4 radius arm bolts effectively giving a flat floor so if somehow I do manage to drag it it won't catch if it rides one arm rather than snagging on the mounts. All good everything is as I might want. However. 2 things are worthy of consideration first off being a gen3 fanboi I know that the aluminium brackets on the older cars are delicate and hurting one ends your day. Are the same concerns valid for the gen4? Second is the weight of the skid I've found, it's 21kg allegedly even though it's only 3mm thick it's quite big so therefore heavy and this ties into point the first is the weight penalty necessary or is the transfer box robust enough on it's own?
12 Nov 2026 11:30 #265550
by saxj
Replied by saxj on topic Gen4 armour advice
I have this one...
Jimny Gen 4 Transfer Case Protection | Des Sol
What I like about this one is that it replaces the transfer case mounts. (I managed to break one on the Gen 3). I don't like the flat plate type, they tend to bend. They also are likely to get you more stuck in mud.
12 Nov 2026 12:37 #265551
by 300bhpton
Replied by 300bhpton on topic Gen4 armour advice
I had this skid plate:
www.asfir.com/products/suzuki-jimny-tran...e/Suzuki/Model/Jimny
Managed to buy a set used for very good money with the plates for the fuel tank and fuel system too, although in reality it was only the transfer box that needed the protection unless you are going lots of rocky terrain. I thought it fit well and being aluminium it was pretty light. But plenty strong enough. It would catch gravel on the top of it though.
I also used Jimnybits radius arm protectors. I don't think you need an entire floor under there as it'll reduce clearance and breakover too much. But you want it protected so that when it does hit, it doesn't get damaged. I'd say rock slider sill bars are also a must on a Jimny too. Although the Jimnybits ones rusted, so I can't recommend those ones.
12 Nov 2026 14:12 #265552
Replied by Lambert on topic Gen4 armour advice
www.sump-guard.co.uk/steel-gearbox-and-t...ard-for-suzuki-jimny
This was the one I was looking at. I get that it's not preserving ramp over angle but it is covering more. On temeraire the one she has is debatable for covering the wiring and that could be a bad day too?
12 Nov 2026 18:30 #265553
by facade
Replied by facade on topic Gen4 armour advice
I have the Jimnybits skid plate, mainly because I have an auto and I didn't think there would be any chance of a second hand transfer box if I broke it (but now there are a lot of JDM autos about there might be a bit more chance)
It seems ok, but it reflects all the noise from the gears* in the transfer box back up into the cabin, I stuck a pad of closed cell foam across it to try and cut the noise down a bit.
*As you may recall, it is one of my continual gripes that Suzuki took what should be a quiet chain drive 'box and went and attached permanently driven gears to the output
- Thank you received: 679
12 Nov 2026 20:43 #265554
Replied by DrRobin on topic Gen4 armour advice
I have the Jimnybits transfer case protector, it seems great, but can collect mud and gravel, although as it has some holes in it and it’s not too big you can get the mud out. The large one you are looking at will probably fill up with mud/gravel.
I also have the Jimnybits radius arm protectors, they are definitely worth it and arguably not required front and rear diff protectors, although the front shows lots of battle scars and I landed very heavily on the rear whilst green laning.
Time to create page: 0.110 seconds
