Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
21/06/09 - New Wheels
When Jimny-Gary sold up I managed to get hold of a set of 16" GV Deep Dish rims, these are for a project later this summer to go to a nice set of 16" based tyres. As I have some time before I buy the tyres I have spent it painting up the rims.
First I cleaned up the wheels with a wire brush
  12378 Hits
17/06/09 - Hogmoor Inclosure
Sunday 14th June saw us off to the Thames Valley 4x4 meeting at Hogmoor Inclosure. Hogmoor is one of the largest sites in the South East offering a variety of off-roading terrains.
Unfortunately the day started off badly, when we got to the site we had great difficulty getting out of the car-park. Bystanders were laughing and shouting to me to put it into 4wd. Usually this is the problem as the old and forgetful forget to select 4wd and wonder why they are going nowhere. In this case the problem was worse, I had selected 4wd already! - there was just no drive to the front wheels. Normally this signifies a major mechanical failure but clearly from the lack of horrible expensive noises etc. the problem was more subtle.
Jimny's havevacuum operated front wheel hubs. These lock the wheels to the driveshafts when 4wd is selected, but they unlock the wheels when in 2wd, this is an economy measure. It was quickly obvious that there was a problem with this part of the system. I then started the laborious process of trying to find a problem in the vacuum system. This involves taking the wheels off and following the vacuum tubes back to the manifold through the various solenoids and valves. There was a good vacuum at the solenoids and the solenoids were switching the vacuum around correctly so it was on to look at the hubs themselves but taking them all apart...
....but I couldn't get the wheels off, my locking wheel nut special socket was on the bench in the garage at home. We hammered an old socket onto the locking wheel nut and drove it off that way....
...then I couldn't get the locking hubs off, they have a modern Torx bolt and I had no Torx sockets with me. We started to try and use a normal socket (not recommended!....
...then without us doing anything there was a loud click and the hubs locked on their own without any further diagnosis or intervention. I suspect there is dirt in the mechanism somewhere so a strip and clean is in order, look out for my next "How to" guide!
So off we went!
About 10 minutes later the car starting emitting those horrible expensive noises everyone dreads. A quick crawl underneath showed that the Transfer Box had decided to part company with the car, the mounting bolts had all shaken loose.
We crawled back to the start with the transmission hanging underneath the car, I found 4 bolts and re-attached the transfer box which was conveniently situated near the red-hot catalytic converter and exhaust expansion chamber (they heat up to red hot heat in order to work and boy did I burn my fingers and arms). This looks to be a problem with the polybush transfer box mounts. I noted earlier on on this website that they increased the vibration in the car and I noticed two weeks ago that the bolts in the mount on the other side had all shaken loose. This time the bolts on this side had shaken right out and damaged the internal threads in the transfer box case. I will have to sort this out and locktite the bolts in, if you have polybush transfer box mounts (such as the Offroad Armory ones) watch out for your mounting bolts on the transfer case shaking loose.
So off we went again! - straight into the mud
  9734 Hits
17/06/09 - Mavericks Jimny - UPDATED
Maverick has sent in some pictures of his nicely modified Jimny.
  15026 Hits
16/06/09 - Robs Jimny
The Offroad Armory are building up their catalogue of parts for Jimnys. I have the Transfer Box Mounting kit on my Jimny.
  10605 Hits
09/06/09 - Another Jimny build
Greg is documenting the build of his Jimny on his website - take a look HERE
  10144 Hits
