Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
13/11/10 - The final push!
So with the axle fitted, the ORA Leading arms fitted and the car sitting on its own wheels at last there are just a couple of small jobs to do to finish off the car.
With it sat on its wheels, the first activity was to loosen off the bolts holding the leading arms in place and re-tighten them. This comes from a discussion with Darrell around the fact that the arms and bushes were installed with the axle hanging down and the car body supported on axle stands. We agreed that this could result in the rubber bushes being tightened with torsional tension them when the weight is put back onto the axle. Therefore I loosend them off before applying the car weight and then tightend them when it was sitting squarely on its wheels.
  10039 Hits
13/11/10 - Marats Jimny - updated
Marat has just bought a new Jimny, its a different style to those we get over here in the UK.
  10140 Hits
6/11/2010 - Fitting the leading arms
So the rebuild work continues on the front axle.
You will recall that the leading arms were bent...the yellow object is a spirit level and the arm curves away nicely.
  17966 Hits
24/10/10 - Welding up the Axle
I had a few hours free today to move it on a bit.
If you recall the mounting holes in one of the Leading Arm mounts were worn oval. Therefore I needed to sort out a repair. This was pretty straightforward. I got hold of some 12mm Repair Washers and ground off the plating (its poisonous to weld them)
  9795 Hits
22/10/10 - The Parts have arrived
You will have read  how I ended last seasons driving..... SEE HERE
And how after a summer of boating I returned to start some work...SEE HERE
And how I am not alone in this task....SEE HERE
Well with bookings coming in for the BigJimny Meet at Tong, my trailer booked for the event and the boat put away for the winter its time to start.....
  11006 Hits
