Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
The owner and site administrator of BigJimny
25/04/11 - Daves Jimny
{pgcooliris id=92|width=800|height=500|numrows=2|otherflashvars=wmode=transparent&showSearch=False&backgroundAlpha=0.0}
  12740 Hits
25/03/11 - "La Keba"
{pgcooliris id=91|width=800|height=500|numrows=2|otherflashvars=wmode=transparent&showSearch=False&backgroundAlpha=0.0}
  12381 Hits
13/03/11 - Changing the Heater Control Bulb
Neil Townley (Nelson83) has sent in his guide to changing the little bulb that illuminates the heater controls, a  common and annoying failure on a Jimny.
  12654 Hits
Tags:
BigJimny@Tong - Were you there??
{pgcooliris id=90|width=800|height=400|numrows=4|otherflashvars=wmode=transparent&showSearch=False&backgroundAlpha=0.0}
Yes! - we did it, probably the largest gathering of Jimnys since the UK launch by Suzuki!
  12638 Hits
04/02/11 - Rear Panhard Rod - updated
So I went out and had another look tonight. This is the starting point with the Panhard Rod mount fouling the Rear Caliper.....
  11532 Hits
