16/02/10 - Changing a Tie-Rod end
Ok so I admit I paid far too much for my new Tie-Rod end (see HERE) , some of you have done better than me on getting a cheap fitting. However, that has not stopped me writing a guide on how to change it.
  11292 Hits
12/01/10 - More bearings!!
We went out to the TV4x4 monthly off-raod event at Oxley's Shaw in December (see the pictures HERE)
  9603 Hits
20/11/09 - Indicator UPDATE
Just an update...
  8968 Hits
17/11/09 - Indicator failure
So I went out today to collect some plywood for the boat (the roll cage makes an excellent roofrack!) and noticed when turning that all four indicators flashed. It doesn't matter which way you turn they all flash together. Fortunately the workshop manual is quite good and goes through a diagnostic to determine whats wrong and it diagnosed that the flasher relay has failed. Its marked up as a DENSO 065500-5350 flasher unit, Suzuki part 38610-84F00. A search of the Internet brought up nothing I can buy (unless I want it in lots of 100!) so its off to the Suzuki dealers (and I bet its not a cheap item!)
  9106 Hits
15/11/09 - CV problems
Folowing a busted CV joint - see Busted  I have spent the last couple of evenings fitting it.
  9669 Hits
