22/10/10 - The Parts have arrived
You will have read  how I ended last seasons driving..... SEE HERE
And how after a summer of boating I returned to start some work...SEE HERE
And how I am not alone in this task....SEE HERE
Well with bookings coming in for the BigJimny Meet at Tong, my trailer booked for the event and the boat put away for the winter its time to start.....
  10748 Hits
2/9/10 - I am not alone!
Andy has sent in some pictures of his leading/trailing arms following a trip out laning in the Peak District as some consolation for me!
As you can see, Andy straightened his by judiciious use of a metal bar being dropped onto the bend.
  9540 Hits
3/6/10 - Starting the Axle rebuild
I started the axle rebuild last night and its not gone too smoothly. The main problem is how to get enough height to drop the axle off underneath the car. With the car having a suspension lift and been generally modified the articulation of the suspension on my car is quite good, which is just what you do not need when trying to drop the axle off.
  9032 Hits
16/05/10 - Thats it!!
Now don't panic, I am not giving up (yet!)
  9337 Hits
24/02/10 - Tie-rod end - UPDATE
So having changed the Tie-Rod end (expensively !!) I took the Jimny down to have the wheels aligned.
  9933 Hits
