Leaking exhaust joint
A while ago I replaced the exhaust on "LittleJimny". Since then I have had great difficulty in getting it to seal. It is a sprung loaded flexible joint so should be a "dry" seal with no sealant or gasket, just a stainless steel mesh ring.
  12372 Hits
Tags:
29/01/10 - Expensive mistake - Update
Just got the new boots from the Suzuki dealers this afternoon. It its clear now what the problem is, the new ones are to the right of each pair in the pictures. The old ones have certainly swollen through the use of oil (now I wonder if oil works on human body parts in the same way ! )
  11026 Hits
27/01/10 - Expensive mistake!
Some of you may have seen my plea in the forum for help re-fitting the small rubbers onto the sliders on the front brake calipers. I spent nearly 6 hours trying to fit them, if you were watching my webcam experiment last night you would have seen me in the garage trying to get them fitted for the second evening.
  11925 Hits
23/12/10 - Caliper Rebuild (part 2)
So the work continues on from Part 1 ( Article CLICK HERE )
If you remember we left it at the point where the piston has been cleaned up and checked for a smooth fit into the caliper.
  15257 Hits
18/12/10 - Caliper Rebuild (part 1)
The Jimny pulls sharply to the right when braking which tends to imply that  the left hand front brake is not coming on properly.
Therefore I decided to strip an rebuild the calipers as they have hard a hard life over the last 3 years.
First I got hold of a Caliper Refurbish Kit from www.biggred.co.uk. - for my Japanese Aisin Calipered Jimny the kit was BRK205131
As you can see it contains the slider boots (therefore is a saving on the Suzuki price straight away!) along with the piston seal ring and piston boots with retaining rings. It also contains some nipple covers.
  12729 Hits
