Subcategories from this category:
Old Man Emu vs Des Sol
17/02/08 - Jimny Lean!
A common problem with a lifted Jimny is "Jimny Lean". This is where it appears to sag on the driver side. The original manufacturers springs are stiffer on the drivers side but most lift kits do not cater for this.
One simple answer is to put a spring spacer in on the drivers side. These are available from "Bits4Vits" in the UK. Here are some pictures of mine.
  12317 Hits
04/01/08 - Fitting a Snorkle
Not my article and not my Jimny - but a good article I thought you would like to see.......
  12529 Hits
29/02/08 - Winch Wiring - dashboard
So having got the wiring looms in, the next stage is to add in the winch wiring. I want to put a remote switch in the dash board, a second battery in the boot and the winch solenoids under the bonnet.
The winch controls will go into the dashboard. There is a handy pocket in the radio/clock mounting frame (shown with a piece of white card inserted) that will take a switch module.
To see how this progresses look at the "Read More" link......
  14849 Hits
31/12/07 - Wiring Modifications - Updated
As can be seen in the problems section, the Jimny wiring needs some serious attention - see Wiring!
A whole series of accessories have been fitted and the wiring for these needs to be rationalised and tidied up. In many places domestic mains cable has been used and lies loose on the floor.
  15539 Hits
18/10/07 - Rear Tyre Mount
One of the problems of fitting large tyres is the one of where to fit the spare tyre. The standard mount will not take large tyres as they foul the bumper and obscure the standard number plate fittings.
When I got the Jimny the previous owner had taken the easy way out and thrown the spare tyre into the rear of the car. This just takes up space and creates a hazard inside the cabin.
  13773 Hits
