Lil Red - SJ restoration - Final Paint - Part 2
IMG-20230508-WA0008
And here she is!!!!
  9926 Hits
Tags:
Lil Red - SJ restoration - Final Paint - Part 1
Processed-WhatsApp-Image-2023-05-05-at-17.27.0114
This week we reached the final stage of the build at Winchfield. The SJ went into final paint.
This is a long post so scroll on down!!
In order to do this the main panels had to be finally fitted. In this procss it was noticed that the front cross members did not fit properly into the new wings. Again this was due to the poor manufacturing quality of the wings.
As you can see the alignment is poor.
  10724 Hits
Tags:
Lil Red - SJ restoration - Fettling and Paint
Processed-WhatsApp-Image-2023-04-21-at-15.35.331
When checking the panel alignment, Winchfield Engineering noticed a slight dent in the sill that we had not seen, On our model of SJ this part is normally covered by a black rubber strip so it seems likely that the sill had gently contacted something and got bent but it was hidden behind the rubber,
Therefore they had to pull the dent out and remove it.
  10300 Hits
Tags:
Lil Red - SJ restoration - Panels back together
Processed-WhatsApp-Image-2023-04-19-at-06.15.2022
A lot of progress this week so there are lots of pictures to look at.
This is the week the panels really get fitted. Up to now it has been trial fitting, alignment and then tacking to hold them in position. Now we are on to "final fit".
First, at the rear, the fuel filler is fitted. This has to be braised into position rather than traditional welding. This is the same as they do in the factory.
  9208 Hits
Tags:
Lil Red - SJ restoration - Wings and Wheel Arches
Processed-WhatsApp-Image-2023-03-28-at-07.24.3211
As mentioned in the previous post for James' SJ, things are starting to go back together. Having bolted down the body it is time to add the doors and tailgate back on to align all the panels and weld them back in place.
After all the filling, sanding and priming, the first step is to ensure all the threads are cleaned out so that the bolts can be run in and out smoothly.
The doors and inner wing threads were cleaned
  8471 Hits
Tags:
