Lil Red - SJ restoration - Preparing the Roll Bar
IMG_20230218_152638907
James wanted a genuine rollbar for his SJ. Now we realise that these roll bars are little more than show items, they are not a competition grade roll bar but it is a factory restore so needs a factory roll bar.
We eventually found one on Ebay. It was not easy to find one but it has been even harder to restore it!. It comes with a white "plastic" coat that at first appears easy to remove as the rust is lifting it up. I took it to the Powder Coaters and they sent it back saying that it simply melted and flowed back whenever they blasted it. In other words, it could be done but would be too expensive in time and money. I then tried sanding, burning with a blow torch and peeling with a sharp edge. It simply would not come off. It took an abrasive wire wheel in an Angle Grinder and close on 4 hours work to shift it.
  3848 Hits
Tags:
Lil Red - SJ restoration - Ready for Welding
WhatsApp-Image-2023-02-15-at-13.24.38
After a lull in work its nearly time to start work on putting it back together. The welder came down to view and in discussions wanted some more sand blasting to be done before welding could commence.
Winchfield have a small sandblaster and a very large sandblaster. The large one is used for really heavy duty cleaning but has to be used outside to avoid filling the workshop with dust.
  3500 Hits
Tags:
Lil Red - SJ restoration - The Rust!!
Processed-WhatsApp-Image-2022-12-09-at-12.46.586
Here is a gallery of some close up details on the rust. Winchfield Engineering have been cleaning out each rust spot back to bare metal ready for preparation.
  3917 Hits
Tags:
Lil Red - SJ restoration - Moving on to the body tub
Winchfield Engineering have moved on to starting work on the body tub.
We always knew this was the bad spot as it had some visible rust on the outside, however it can be a bit of a shock as to how bad a "good" car can be.
Here on the drivers side rear we can see the panels that create the rear of the arch have trapped water etc and quietly corroded inside.
  3746 Hits
Tags:
Another SJ Build - Sam's Yellow SJ - An update
Sam has sent in an update on the progress of his SJ. Many thanks Sam!
These SJ restoration projects are proving popular at the moment, if you have some work in progress why not send in the details to show them on this website?
As you can see, the body was stripped of all major components and then removed from the chassis.
In Sam's case this was to assist in a planned upgrade from the 4 speed gearbox to a 5 speed along with a general rebuild of the transmission.
  3969 Hits
Tags:
