Welcome to BigJimny
BigJimny is YOUR resource for everything to do with Suzuki Jimnys.
If you are new to the site then REGISTER through the LOGIN button
There is a friendly, active FORUM to discuss Jimny related subjects and a web SHOP for all your parts needs.
AS WITH ALL WEBSITES YOUR ATTENTION IS DRAWN TO THE DISCLAIMERS . As this website does not require a login to access content, the accessing of this website and associated resources is deemed acceptance of these DISCLAIMERS. Do NOT progress if you do not accept the DISCLAIMERS
Lil Red - SJ restoration - First look at the panels.
SJ-rebuid-53
With the bolts in full retreat, Winchfield Engineering had a first look at the body panels.
Around the rear, with the wing panels and taligate removed, some more rust became visible.
This is behind the panel, so can be fixed with some fabrication rather than a replacement panel.
On the left you can see the end of the rear crossmember which will need some work to ensure the rust is completely removed
It looks worse than it is really, it should clean up fairly easily.
  5491 Hits
Lil Red - SJ restoration - Attacking the rusted bolts
SJ-rebuid-55
As you will have seen in the last post, a number of the large hinge and panel bolts are rusted solid, so Winchfield Engineering needed to get serious!
 In the picture on the left you can see a nut being held onto the bolt using MoleGrips.
They went around the SJ, welding nuts on all the stuck bolts
  5177 Hits
