× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
Brakes pulling to one side
  • Gromit
  • Visitor
  • Visitor
19 Dec 2010 08:37 #7794 by Gromit
Replied by Gromit on topic Re: Brakes pulling to one side
Think I need to have a look at mine again. It recently pulled to the left violently under braking and the cause was found to be a seized piston on the right side (not braking). I sorted it out but at the time I noticed that the polished surface on the piston was in poor condition.
It's now starting to pull again so I presume that the piston is rusting due to the poor finish so is the only answer a new piston ?
  • mlines
  • mlines's Avatar Topic Author
  • Away
  • Administrator
  • Administrator
    Super Users
  • Wokingham, UK
19 Dec 2010 08:48 #7795 by mlines
It probably depends on how poor the surface is, mine cleaned up with a wipe of wet n'dry and solvol autosol. If you need a piston then try www.brakesint.co.uk or www.biggred.co.uk.
Facade - yes - thanks for reminding me about the sliders. I do remember finding they have different part numbers but mine have been apart so many times without me checking they are thoroughly mixed up, I will get my micrometer out and measured them. If I find a difference I will then have to try and work out what to do!
Bleeding should be straight forward. I have disks on the rear as well so I will probably have a quick look at those pistons as they have been on a year now. Bleeding the back is a bit more involved as the calipers are not quite upright so you have to rotate them slightly to get the bleed nipple to the top if I remember correctly.
  • mlines
  • Away
  • Administrator
  • Administrator
    Super Users
  • Wokingham, UK
22 Dec 2010 19:37 #7986 by mlines
Well I measured the sliders today and they are all but identical.
One is 0.5mm thicker that the other, but I would guess that that is within the tolerance of manufacture, particularly as both when cleaned up are a loose fit into the caliper.
22 Dec 2010 20:05 #7988 by kirkynut
Have you looked into how much good second hand calipers are from camsuzuki? Especially with the discount we now get and the service we've been promised.
If cheap enough it would be much less hassle and you could re-build the old ones slow time in the future so you always have a goos pair on the shelf in case it happens again - without the car being out of action.
Just a thought - I've got a set of calipers from the new front axle I bought as the scrappies left them on - I just hope they weren't the reason the car they came from crashed!
  • Skinhead
  • Visitor
  • Visitor
15 Oct 2012 17:23 #50332 by Skinhead
Replied by Skinhead on topic Brakes pulling to one side
Ive got this problem now from offroading in the sand yesterday, ive been told it could be the sliders and im hoping it is even though i dont know what they are :ohmy:
  • Gromit
  • Visitor
  • Visitor
15 Oct 2012 19:11 #50347 by Gromit
Replied by Gromit on topic Brakes pulling to one side
The sliders as people call them are the brake caliper pistons that seize in the caliper mounting causing the brake on that wheel work poorly which makes the other brake pull the car to that side.
Example - Seized caliper piston on right front wheel will make the car pull to the left !
  • Skinhead
  • Visitor
  • Visitor
15 Oct 2012 19:15 #50348 by Skinhead
Gromit wrote: The sliders as people call them are the brake caliper pistons that seize in the caliper mounting causing the brake on that wheel work poorly which makes the other brake pull the car to that side.
Cheers mate, will take caliper off tomorrow and have a play. Mind doest pull when braking, it turns! Could drive round a small roundabout!
  • markyp2000
  • Visitor
  • Visitor
15 Oct 2012 19:27 #50352 by markyp2000
Replied by markyp2000 on topic Brakes pulling to one side
Seized caliper piston on right front wheel will make the car pull to the right as the brake wont relise and make it come on before the other/left brake because the brake pressure is higher than the relise pressure so the piston comes out but wont get pushed back in
  • supergaz
  • Visitor
  • Visitor
15 Oct 2012 19:29 #50353 by supergaz
Replied by supergaz on topic Brakes pulling to one side
Just remember not to use WD40 to clean them!
  • Skinhead
  • Visitor
  • Visitor
15 Oct 2012 19:33 #50354 by Skinhead
Im pretty sure its the passanger side not working, it drives in a straight line until i brake, the brakes are realy poor an it turns to the right.
  • supergaz
  • Visitor
  • Visitor
15 Oct 2012 19:34 - 15 Oct 2012 19:36 #50355 by supergaz
Jack up the front and give the front wheels a spin, you may feel one side binding.
Last edit: 15 Oct 2012 19:36 by supergaz.
  • Skinhead
  • Visitor
  • Visitor
15 Oct 2012 19:37 #50357 by Skinhead
supergaz wrote: Just remember not to use WD40 to clean them!
Why not??? Thats what i was going to do, do i use that red grease or what ever it is?
Powered by Kunena Forum
