Front brakes improvement
13 Nov 2023 13:58 #252094
by j1c7
Front brakes improvement was created by j1c7
Hi,
I recently modified my Jimny to run 33"s and found that the breaking with those tires is really deficient. I have seen from this forum that the Gran Vitara or sidekick front brakes can be installed in the Jimnys (and therefore being able to use ventilated discs and a 13% larger caliper), however, I couldn't find which specific models should I be looking for.
In my country we have 2 Sidekick versions, the 2 and the 4 doors. Also for the Gran Vitara, from the 2nd hand seller, there are 4 versions, the one from 1999-2005 and another from 2006-2017 and each also came in 2 and 4 doors versions from what I understood.
Does anyone has any idea on which one I should be looking for? I would the ones from the BigJimny store, however, which shipping and customs to my country, the cost almost triples.
Another option is waiting for the new 4 doors Jimny, which comes with ventilated brakes from what I understand. Does anyone knows of the caliper is also bigger on the new 4d Jimny?
- Thank you received: 180
13 Nov 2023 17:14 #252097
by 300bhpton
Replied by 300bhpton on topic Front brakes improvement
What Jimny do you have?
Vented discs won't necessarily provide anymore stopping power, as that will depend on surface area of the disc and pad. Vented discs have greater heat dispersal, so rather than being stronger braking, just means they can handle more heat for longer, such as from a larger heavier vehicle.
- Roger Fairclough
- Thank you received: 210
13 Nov 2023 19:58 #252102
by Roger Fairclough
Replied by Roger Fairclough on topic Front brakes improvement
Or if he is towing to the max. allowed down a steep hill on a hot day.
Roger
Roger
13 Nov 2023 21:21 #252105
by 300bhpton
Not really. Unless the vehicle has under specced brakes. Most times they should be designed to cope with the vehicles maximum train weight. Also let’s not forget the unbraked trailer towing limit is low. Anything brakes should make it a non issue.
- Roger Fairclough
13 Nov 2023 22:02 #252109
by Roger Fairclough
It's not under specified brakes that are the problem, but the over specified tyres. When you fit such huge tyres to a Jimny, the standard brakes are being pushed to the limit as the author found out. I would suggest a change to a vented disc with suitable pads would be a good idea. I will leave it to others to advise as to where to get the parts. One last point, the front brakes do most of the braking so I do not see the need to convert the rear to a disc set-up.
Roger
Roger
- Thank you received: 415
13 Nov 2023 22:47 - 13 Nov 2023 22:49 #252112
Replied by yakuza on topic Front brakes improvement
I am using 4 door 93 to 98 Vitara/sidekick calipers and hangers and diesel jimny discs. My car got ABS so the disc center is 107.8 ish. Non ABS is 107 and can use vitara/sidekick discs.
I have no experience with such large wheels on road.
I will Try dieseljimny every thing the next time I order spare brakes.
Last edit: 13 Nov 2023 22:49 by yakuza.
15 Nov 2023 00:00 #252130
by j1c7
Replied by j1c7 on topic Front brakes improvement
I have the JB43. Even if the caliper size is the same and I dont increase the stopping power, I sometimes drive roads with long and really steep downhills, so, I still see an advantage in having the vented discs.
15 Nov 2023 07:16 #252131
Drove alot of hills thru Norway together with a group of Jimnys in August and their brakes were smelly and really hot.
I pulled a trailer and mine did not smell.
(Funny how Danish people is not so used to any hills and was not familiar with the smell of a real Norwegian downhill )
- Roger Fairclough
15 Nov 2023 08:13 #252132
by Roger Fairclough
16 Nov 2023 00:02 - 16 Nov 2023 00:02 #252147
by j1c7
Yes, completely agreed. My Jimny is a manual a normally I will select 2 gear and use the engine compression instead of using the brakes constantly.
Yakuza, I'll try to use the calipers and hangers that you are using. Mine is the non ABS, so I should be able to use the vitara/sidekick discs.
Last edit: 16 Nov 2023 00:02 by j1c7. Reason: typo
16 Nov 2023 06:19 #252148
I learned at 18 that my 1985 Fiat actually could not be filled with 3-4 mates and camping gear and a trip into the mountains. Or at least not the return trip. Had to stop half way down to let it cool off. I barely managed to stop thanks to a side road.
Any Suzuki with a larger diameter vacuum brake pump to increase brake pressure for larger tyres?
The large Vitara lwb maybe?
I know the Jeep folks will install Hydro assist at around 35" tyres but their brakes are bad from factory.
On my SJ with 31" I think brakes where OK and far better than a 1985 Fiat anyway.
Most likeley. But then there is also the hills that is too long and steep for the low gears and brakes must be used intermittent to let them cool down between the slow downs. Not constant braking, but in intervals.When I started driving, disc brakes were in their infancy and so I quickly learned ( and my dad told me as well ) that you used the gears to help you slow down. I would imagine the same would apply to a Norwegian but maybe not so to a Dane who would be more accustomed to a flatter landscape .
Roger
- Thank you received: 178
16 Nov 2023 20:30 #252164
by gv42
Replied by gv42 on topic Re:Front brakes improvement
I have fitted the bigjimny vented disc conversion to 3 jimnys , DEFINITELY makes a difference in braking power and feel... and aiming to fit it to a 4th, have to recalibrate how you brake in the wet ( with bfg ko2) something you didn't have to do with standard brakes
Sent from my SM-S918B using Tapatalk
