Re:Re:Location for aftermarket oil pressure sensor?
- Roger Fairclough
- Thank you received: 211
22 Jan 2023 18:18 - 22 Jan 2023 18:19 #247090
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Location for aftermarket oil pressure sensor?
Last edit: 22 Jan 2023 18:19 by Roger Fairclough.
23 Jan 2023 09:25 #247108
by Vandoni
Replied by Vandoni on topic Re:Re:Location for aftermarket oil pressure sensor?
So you just screwed a line into the stock oil pressure sensor position and added the y piece with the stock and aftermarket sensors?
- Roger Fairclough
23 Jan 2023 14:39 #247118
by Roger Fairclough
Basically yes. The end you screw into the block needs to have a tapered thread at both ends, but the block end needs to be to suit the thread at that end. Mine was 1/8" gas thread but you can check yours with your hydraulic fittings supplier. The other end needs couplers that suit the "T" or "Y" piece that you buy. Use PTFE tape at all tapered thread joints and make certain that your hose is long enough to accommodate any engine movement.
Roger
Roger
The following user(s) said Thank You: Vandoni
23 Jan 2023 15:49 #247122
by Vandoni
Mh ok, i'll see if I can make something like that in my case, thanks for the info!
29 Jan 2023 16:26 #247256
by Motacilla
Replied by Motacilla on topic Re:Re:Location for aftermarket oil pressure sensor?
Here's an alternative approach, using an adapter under the fuel filter. Allows both a pressure and a temperature sensor.
LINK
This is a Gen4, dunno if it'll look the same under your Jimny. Japanese language site, use your favorite translation tool or just follow along with the photos.
Good luck!
LINK
Good luck!
- Roger Fairclough
30 Jan 2023 09:48 #247265
by Roger Fairclough
Link doesn't work for me.
Roger
Roger
