Re:Re:Location for aftermarket oil pressure sensor?
21 Jan 2023 09:01 #247050
by Vandoni
Location for aftermarket oil pressure sensor? was created by Vandoni
So as the title suggests, I want to install an aftermarket oil pressure sensor and gauge, but I don't know where I could put the sensor, the gauge already has a spot for it, any advice?
thanks in advance
thanks in advance
- Roger Fairclough
- Thank you received: 217
21 Jan 2023 09:12 #247051
by Roger Fairclough
Replied by Roger Fairclough on topic Location for aftermarket oil pressure sensor?
The sensor for the oil pressure gauge goes in place of the "idiot" sensor that will be found close to the oil filter. I am assuming that the Gen.3 is similar to my Gen.4, I see no reason why it shouldn't be.
Roger
Roger
21 Jan 2023 16:38 #247065
by Vandoni
Replied by Vandoni on topic Location for aftermarket oil pressure sensor?
The stock sensor is a switch I think, so it won't light up a bulb unless there's no pressure, also yes it is near the filter and it has a cable connected to it, but won't removing it trigger any CEL?
- Roger Fairclough
21 Jan 2023 17:42 #247066
by Roger Fairclough
You remove the standard sensor and attach it to a "Y" or "T" piece so that the original sensor and the pressure gauge sensor both get oil under pressure.
Roger
Roger
The following user(s) said Thank You: Vandoni
21 Jan 2023 19:00 #247069
by Vandoni
Clever, didn't think about that, thanks for the tip
21 Jan 2023 19:41 #247070
by fordem
Replied by fordem on topic Location for aftermarket oil pressure sensor?
Please don't put a tee directly on the side of the engine block, I suggest the tee be securely mounted either to the firewall or the inner fender, which ever is convenient and connected to the block via a braided stainless steel flex.
Tees mounted directly on the block will generally fatigue from the vibration and break.
If you're in the UK Demon Tweeks should be able to supply what you need.
