Re:Re:Location for aftermarket oil pressure sensor?
21 Jan 2023 22:22 #247073 by Roger Fairclough
I did just that and it meant I had another benefit. If you screw the "T" or "Y" piece to the block directly, because the end you screw in is a tapered thread you may not get it to line up where you need it to be. The sender unit is large and cumbersome and heavier than the original sender so I went to a hydraulic fitting specialist called Pertex - I think that's the spelling - supplied everything.
Roger
21 Jan 2023 22:38 #247074 by Roger Fairclough
It's spelt Pirtek.
Roger
22 Jan 2023 00:03 #247076 by Vandoni
Oh damn for real?
No I'm not in the UK so I'll have to do myself since it's a simple enough job I think, but what do you mean with a braided steel line, how should it be connected?
Just explain it like I'm 7 because it's late here and I'm really tired, thanks tho
22 Jan 2023 08:49 #247078 by mlines
The 1.3 version of the old swift had an oil pressure gauge apparently.
I don't have the diagrams for the swift to confirm this but that would be a variant of the M13 engine
Sent from my moto g42 using Tapatalk
22 Jan 2023 14:37 - 22 Jan 2023 14:37 #247080 by Vandoni
My Jimny has the m13a but the oil pressure sensor is just a on/off switch, unfortunately
Last edit: 22 Jan 2023 14:37 by Vandoni.
22 Jan 2023 14:59 #247081 by mlines
Vandoni wrote: My Jimny has the m13a but the oil pressure sensor is just a on/off switch, unfortunately
Yes but the swift may have the parts to allow a gauge to be fitted
Time to create page: 0.299 seconds
