Gen4 Headlight Auto Levelling Initiallisation
04 Aug 2023 07:08 #250110 by Soeley
I will do it later when I finish work, the screen shots are from the Suzuki Worshop Manual which I boughtbfrom my main dealer. Not sure if they are still available now?
05 Aug 2023 08:30 #250113 by Soeley
I think these are what you are after.
When you say it lowered the headlights too much when load was added to the rear, could it be the case that the headlight aim was just set too low even without any load in the rear, but was less noticable?
07 Aug 2023 12:30 #250141 by GaSSiS
Thanks a lot for the instructions. At the end of that week I checked the correct operation of the auto-corrector by putting 4 people in the Jimny, and the headlights lowered correctly. But the headlights do not react to the loading of one or two people. Apparently, the fact is that the dealer's master was sitting in the car at the time of calibration, and therefore the car considered his weight as part of the weight of the car. I will try to come to the dealer again and ask to recalibrate with an empty cabin
11 Aug 2023 08:27 #250221 by GaSSiS
Finally, I once again drove to the official dealer. This time, they read the workshop manual themselves and admitted that they were wrong the first time by calibrating the sensor with the driver inside car. Recalibrated on an empty car. Everything is working fine now, thanks everyone :).
The following user(s) said Thank You: mlines, Soeley
11 Aug 2023 10:02 #250223 by Soeley
Glad you got it sorted, mine still doesn't work :(
11 Aug 2023 15:48 #250226 by lightning
lf the system does nothing at all, with no warning light, have you done some simple checks like fuses.
Maybe you stalled the adjustment motor and it blew a fuse.
You would think that the system would at least attempt to initialise even if the zero point wasn't correct.
