Re:Jimny Bits Swaybar (Anti Roll Bar) Quick Disconnect. Thoughts ?
- Rabid Rhino
- Elite Member
- Thank you received: 33
10 Apr 2022 16:19 #242835
by Rabid Rhino
Replied by Rabid Rhino on topic Re:Jimny Bits Swaybar (Anti Roll Bar) Quick Disconnect. Thoughts ?
Ordered. No diy kits so it's the pre-cut pre-welded fully assembled by Jimnybits option which I'll gladly take so don't have to ask anybody to cut an Anti Roll Bar in half then send it to me.
Jimnybits also list off all the additional parts needed which I ain't got so vey helpful.
- Rabid Rhino
- Elite Member
10 Apr 2022 16:30 #242836
by Rabid Rhino
Alternate options. I wonder why JimnyBits didn't do cut end links like these few examples.
(If I ever get a complete ARB I'll look at replacing the Jimny bits one and getting some disconnecting end links that fit straight from the supplier or even getting some modified to fit mabe even completely fabed.)
- Thank you received: 1928
10 Apr 2022 17:59 - 10 Apr 2022 18:00 #242838
Replied by Lambert on topic Re:Jimny Bits Swaybar (Anti Roll Bar) Quick Disconnect. Thoughts ?
Because they know their market, the shiny stuff like that is not going to sell as well as it might in the Jeep community because there's a perception that Jimny stuff is budget end not high end.
Last edit: 10 Apr 2022 18:00 by Lambert.
The following user(s) said Thank You: Rabid Rhino
10 Apr 2022 21:11 #242842
by Busta
Replied by Busta on topic Re:Jimny Bits Swaybar (Anti Roll Bar) Quick Disconnect. Thoughts ?
They wouldn't work on the Jimny. The Jimny drop links are very short and, with one removed, the end of the ARB passes very close to the droplink bracket (it may even hit the bracket, depending on how well your ARB is aligned in the chassis bushes.) You need to completely remove the drop link for it to work.
- Rabid Rhino
- Elite Member
10 Apr 2022 22:40 #242845
by Rabid Rhino
Busta.
And therein probably lies the reason why Jimnybits did it the way they did.
Lambert
$59 for 2 steel tubes with 2 steel tabs welded to them ain't cheap. Makes those $120 jeep end liinks look like good value.
I need to check how much my complete kit was with the used ARB.
Lambert
11 Apr 2022 03:35 #242847
Ah yes value for money Vs sale price, there's a can of worms and no mistake!
Time to create page: 2.167 seconds
