BigJimnyMeet 2024
Rear gearbox oil seal
- Danparry
- Visitor
07 Sep 2021 11:33 #238313
by Danparry
Replied by Danparry on topic Rear gearbox oil seal
OK thanks heaps,
I hope it all works for me lol
Also with the epoxy would jb weld be OK or dynagrip dynasteel work fine?
- Thank you received: 653
07 Sep 2021 20:06 #238323
Replied by jackonlyjack on topic Rear gearbox oil seal
If it's leaking from the prop cap the seal is possibly ok
So seal the cap and see if it stops leaking
- Thank you received: 82
07 Sep 2021 20:11 #238324
by Dirtbird
Heavy Duty Transfer Box Brackets, 2-inch Black Raptor lift kit, caster adjusters, Rust removed and stich welded new sections. Galvanised Chassis. Body,Engine,transmission swap. Anti Rollbar Roll / Sway Bar / DAVES ARB disconnect kit.Osram Night Breaker Head light mod and white 501 led side lights.
Replied by Dirtbird on topic Rear gearbox oil seal
Might just do that while I can...Have a look at this.
www.bigjimny.com/mediawiki/index.php/Gea...put_end_oil_leak_fix
- Danparry
- Visitor
08 Sep 2021 05:54 #238328
by Danparry
Yeah I'll have a look tonight.
I noticed it's shakey a little now at low rev/idle I think the gear oil may be low
I'll have do top it up tonight and take a look
- Danparry
- Visitor
08 Sep 2021 09:46 #238338
by Danparry
So i just got home from work and checked the gearbox oil,
it was fine thank God for that
It only took one pump of my oil filler and oil started running out, so I'm stoked about that
Still waiting for my oil seal to arrive in the post,
Also I bought some of this epoxy today to use to fill on the shaft,
Would this be fine?? It says it's used in high heat areas,
Engine blocks, bbqs mufflers ect
- Danparry
- Visitor
15 Sep 2021 06:34 #238620
by Danparry
I received my oil seal today, the post has been very slow lately,
just a question would I be right to assume that the side of the seal with the lip goes into the gearbox and the flat side faces out towards the propshaft?
also do I just grease the entire seal up before installing it aswell??
I've got some pics there of the seal
15 Sep 2021 07:41 #238624
by Dirtbird
The flat side facing out the lip facing into the gearbox. A trick to get the old seal out is to drill in two wood scerws into the old seal and pull out gently with a pliers. like this
Not a great vid but you get the idea
- Danparry
- Visitor
15 Sep 2021 08:38 #238626
by Danparry
Thanks
I just found this video and it looks like it's the other way around in this video?
He has the flat side facing toward gearbox and the lip facing out towards the prop shaft?
Unless he had it installed wrong?
15 Sep 2021 08:44 #238627
by Dirtbird
Yes, Video is correct should have been more precise in the reply.
- Danparry
- Visitor
15 Sep 2021 09:18 #238630
by Danparry
No worries
Thank you
Thank you
15 Sep 2021 09:30 #238631
by Dirtbird
My bad Dan . That's a nice bit of work you're taking on. Post us a few pics to see how you're getting on...
- Danparry
- Visitor
15 Sep 2021 11:03 #238632
by Danparry
Thanks
Yeah will do
Yeah will do
Time to create page: 0.141 seconds
