BigJimnyMeet 2024
2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
25 Jan 2021 07:29 #232169
by RainerK
Replied by RainerK on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
This would be GREAT!! and Thank you.
I have the Swift wiper switch but for those that have the original one (and also for me) the mod for just intermittent wipe would be sufficient, especially if it is not too complicated and would not require additional cables from the front to the back.
- Thank you received: 479
22 Feb 2021 21:18 - 22 Feb 2021 21:40 #233115
Replied by Soeley on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
Update time,
I have (thanks to Martin for pointing it out to me) reconfiguerd the way the realy circuit connects to the Jimny.
Now this is only if you have the later Swift style switch fitted with the INT position on the Rear Wiper.
The original Grey wire I had removed from the block is now put back into position, the output wire from Realy 3, #30 is now spliced into this.
The switch has an unused pin, #1 (zoom in, you can just see the numbers)
Corresponding hole in the connector block
Flylead with small terminal fitted into the hole. I opened it up with a 3mm drill the went down it with a small square needle file.
Connected up to the Relay circuit, Relay 1, #85
And the final diagram tweaked to show the update
Finaly a video of it in operation
Last edit: 22 Feb 2021 21:40 by Soeley.
13 Sep 2021 17:27 #238565
by Dan
Replied by Dan on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
I noticed something that I haven't picked up on in any previous cars.
With the wipers on constantly, when I accelerate they slow down.
When I lift off the throttle, they speed up. I've never noticed this before.
- Thank you received: 77
13 Sep 2021 17:40 #238567
by fordem
Replied by fordem on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
Get yourself one of those volt meters that plug into the cigarette lighter outlet and monitor the voltage there, I suspect you'll find the voltage drops a volt or two when you accelerate and comes back up when you lift off the throttle.
More & more modern vehicles are being supplied with "smart" alternators that allow some degree of control by the ECU and reduce output voltage when the "mechanical load" on the engine increases - it's done to reduce fuel consumption.
The following user(s) said Thank You: Dan
14 Sep 2021 12:20 #238597
by Dan
How about accessing Soeley's secret menu and watching the voltage from the infotainment screen?
www.bigjimny.com/index.php/forum/8-my-ji...-black-sz5?start=144
14 Sep 2021 18:57 #238611
by Dan
I've answered my own question.
The hidden screen was ranging from 12.2 to 14.8v during normal driving on my commute.
That was with the stereo on mute and only the drls on, with the fan on as low as it goes, so not a massive load.
I suspect I could have got the numbers to change a little if I wellied it.
- Thank you received: 552
15 Sep 2021 07:24 #238621
by Scimike
Replied by Scimike on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
Just trying to educate myself on all the modern stuff, I assume the G4 is a smart alternator?
Only asking as the voltage range above is going to what I would consider to be limits. In the old days 12.2 was considered a flat battery and 14.8 was heading to overcharged.
Yes you will see things speed up / slow down with this level of voltage fluctuation. Is this normal for smart systems?
30 Aug 2022 13:53 #244789
by Auszooker
Replied by Auszooker on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
Here is my method of adding an intermittent function with a swift stalk, note I am in Australia and our stalk is on the left of the column, it seems the pin numbers are backwards, but not colours.
Basics of it are a timer module that you can vary the on time and off time, off time is the delay between wipes and on time only needs to be very short, about .2 of a second to get the wiper moving and then the self park feature will take over.
You can power your timer from the thick grey wire, this has power when ignition is on, for the earth we will feed it via the rear int switch in the Swift stalk, this switches to earth when turned on, for that a pin needs to be added into the plug in position 10 (nothing there in a Jimny) So that makes our timer turn on when needed, all other times it does nothing.
To make things happen, we need to pulse the rear wiper motor control wire (thin grey) to earth to get it to do a sweep, to do this we will cut the wire and loop it through the changeover relay on the timer, with the common terminal hooked up to the motor side of the wire we cut and the stalk side to the normally closed side, then we will connect the normally open terminal to the black earth wire. So when the timer is doing nothing, the thin grey wire passes through the relay so none of the wash and wipe or on functions are interrupted and then when the timer is engaged, it pulses the relay to earth.
If this makes sense to you then finding a timer you like should be easy, the extra terminal you need to add is a bit of a hard one, It's a Sumitomo HE060 uninsulated terminal which seems to be available genuine only which means buy 50000 or get reamed, but look around and you might find something.
I make and sell these ready to go along with the HE060 terminal crimped on a wire, in Australia. I could look at adapting them to fit a UK car but I don't see if being economical, verse creating your own.
01 Oct 2023 08:23 #251109
by Pajoe
Replied by Pajoe on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
How much?
- rogerzilla
- Thank you received: 65
01 Oct 2023 10:12 #251115
by rogerzilla
Replied by rogerzilla on topic 2019 Jimny Intermittent Rear Wiper Mod Gen4 (JB74)
This is also a popular mod on the 3rd generation Mazda MX-5, using an RX-8 stalk to get variable intermittent wipe. I haven't bothered in my MX-5 because I don't intentionally use it in the rain. You think Jimnys rust...!
Time to create page: 0.226 seconds
