Re:Jimny jb74 pulling to the left
- Thank you received: 11
04 Sep 2020 20:26 #227739
by wicho001
Sent from my SM-G975F using Tapatalk
Replied by wicho001 on topic Re:Re:Jimny jb74 pulling to the left
Nice!!...Your welcome.Thanks, I'd seen his other video but not that one. Got to say I fitted the Osram LEDs before he did
- Grim Reaper
- Senior Member
- Thank you received: 10
04 Sep 2020 22:15 #227743
by Grim Reaper
Replied by Grim Reaper on topic Re:Re:Jimny jb74 pulling to the left
I wonder if some adjustment has been made that is now causing the power steering to try to return the steering wheel to centre? If you have not removed the steering wheel or changed the connections on the steering column in the engine bay (thus changing the wheel position in relation to the steering box input shaft position) then centering the steering wheel should align the yellow paint marks on the steering box input shaft and housing (there were paint marks on mine so I guess there will be on others as well).
If we take this as a factory set centre position, keeping the steering wheel centred, the only adjustment that should be required is to the drag link from the pitman arm to the nearside wheel to straighten the front wheels up. There should be no need to adjust the rod across the back of the wheels. this adjusts the toe in which didn't change when the axle was lowered in relation to the body
05 Sep 2020 03:31 #227746
by wicho001
Replied by wicho001 on topic Re:Re:Re:Jimny jb74 pulling to the left
The only thing that has been touched is the rod. I will take a look at the yellow mark tomorrow. Cross fingers!I wonder if some adjustment has been made that is now causing the power steering to try to return the steering wheel to centre? If you have not removed the steering wheel or changed the connections on the steering column in the engine bay (thus changing the wheel position in relation to the steering box input shaft position) then centering the steering wheel should align the yellow paint marks on the steering box input shaft and housing (there were paint marks on mine so I guess there will be on others as well).
12 Nov 2020 13:54 - 12 Nov 2020 13:55 #229962
by wicho001
Last edit: 12 Nov 2020 13:55 by wicho001.
Time to create page: 0.117 seconds
