Re:Jimny jb74 pulling to the left
  • wicho001
04 Aug 2020 16:59 #226086 by wicho001
Replied by wicho001 on topic Re:Re:Jimny jb74 pulling to the left
mlines wrote: Have you adjusted the steering wheel to be central after the lift?
Yes they did, on both shops but when I ride I have to compensate.
The picture attached show where the steering wheel goes without any imput.
Sent from my SM-G975F using Tapatalk
04 Aug 2020 18:50 #226088 by Roger Fairclough
I am assuming that the comment re: and the wheels moving freely was ascertained after the front axle was lifted on a jack. If so it's possible that when you brake the piston/slide is reluctant to move back due, to dirt or rust, so jack up again, put the brakes on and quickly check for free rotation.
Also check the back brakes and see if during the lift the h/brake cable was inadvertently snagged causing the near side to drag.
Roger
04 Aug 2020 18:57 #226089 by Roger Fairclough
Another thought. You drive on the right so if your Jimny is pulling to the left it is climbing up the camber of the road.
This is very odd!
Roger
  • wicho001
04 Aug 2020 20:52 #226091 by wicho001
Replied by wicho001 on topic Re:Jimny jb74 pulling to the left
Thanks Roger.
Left the Jimny at the dealership, lets see what they say about it.
  • wicho001
11 Aug 2020 19:29 #226532 by wicho001
Update: I have the car back, the car still pull to the left (not as much as before) and the steering wheel still not centered, going back to the dealership tomorrow.
  • wicho001
11 Aug 2020 21:16 #226537 by wicho001
The only thing left to check is the caster correction bushes that were installed with the suspension kit. Does anyone have an instruction manual for these? My kit arrived without one.
Time to create page: 0.284 seconds
