INOX in new Jimny Lead-Acid Battery (JIS). It works!
- Thank you received: 479
- Thank you received: 320
- Thank you received: 584
I remember in The Olden Days motor factors sold tubes of "de-sulphation tablets" that never worked, but that was most likely because the problem wasn't sulphation, but shedding of active material and disintergration of the plates.
The internet consensus seems to be adding saturated epsom salt solution (magnesium sulphate) and trickle charging will remove existing sulphation, but I've not found the chemistry behind it. The best way to prevent sulphation is to keep the battery charged.
- Thank you received: 1761
- GeorgeC
- Visitor
I thought I had a recalcitrant alternator but it turned out to be a crook wire/connection at the computer end of the LIN circuit. This was confirmed by the Suzuki Roadside Assist-RAC Battery Technician three weeks back, and yes, correctly diagnosed by Martin about this time last year!
As for the car, it has now been called home, more details when I know.
- Thank you received: 71
l've never worried about the battery, it's always started up with no issues and shows no signs of becoming depleted.
l used to worry about the battery going flat in my Triumph Herald back in 1982, but that only had a dynamo which didn't charge at all when the engine was at low RPM
- GeorgeC
- Visitor
www.inoxmx.com/products/mx2-battery-conditioner/GeorgeC wrote: Yes, It still works after 18 months!
A recent test showed a Specific Gravity of 1282-1285, a bench Resting Voltage of 12.76V, and a Cold Cranking Amps test of over 500CCA!
l've got one on my motorcycle, as it doesn't move all winter.
But if the vehicle is in use even if it's not every day it shouldn't be necessary.
