Jimny following camber of the road
23 Nov 2018 21:24 #198079
Replied by mlines on topic Re:Jimny following camber of the road
As said above, never use an oil based grease or lubricant near rubber. The rubber absorbs the oils and swells up, in brake calipers this jams the sliders. This include WD40 or 3in1 you may try to lubricate the slider with.
Here are mine from a good few years ago, old and new side by side
The following user(s) said Thank You: Lambert, paradox1001
- paradox1001
23 Nov 2018 21:31 #198080
by paradox1001
Replied by paradox1001 on topic Re:Jimny following camber of the road
Martin whilst your here
I use tapatalk app to use the forum
I can’t see most of the pictures and the quote button throws up an error
Any ideas on how to sort it?
23 Nov 2018 21:35 #198081
There is a known bug which means you cannot see pictures in some circumstances.
Also I am seeing the quote issue as well, but have no solution at the moment
The following user(s) said Thank You: paradox1001
- paradox1001
23 Nov 2018 21:58 #198083
by paradox1001
I’m glad to know it’s not a problem that’s just at my end then
- Bill Portland
- Thank you received: 77
23 Nov 2018 23:10 #198084
by Bill Portland
Replied by Bill Portland on topic Re:Jimny following camber of the road
Martin, did you get my pm on this subject?
My pm seems to have been cut off too
Sent from my D6503 using Tapatalk
24 Nov 2018 06:56 #198087
by facade
Replied by facade on topic Re:Jimny following camber of the road
Glad you have sorted it, but it wasn't really following the camber in the road if it was a dragging brake, it was veering left.
My bad, I should have asked you to verify it was following the camber by driving on the crown of the road, if not the "wrong side", could have saved us a bit of headscratching.
Time to create page: 0.263 seconds
