2" Black Raptor lift kit
- TomDK
- Visitor
Use a jack under chassis, unbolt shock mount, lower axle.
You can see me do this in this article
www.bigjimny.com/index.php/bigjimny-blog...rebuilding-the-front
- GRAYWOLF
- Visitor
Didnt wanna undo too much..you know..
But, ill have a play now.Many thanks.
- Thank you received: 1761
- TomDK
- Visitor
11/60 wrote: I have to say I am with Tom on this. Suspension is arguably only second in importance to tyres when it comes to vehicle dynamics. I spent nearly twice as much as the black raptor kit just on dampers and I thought they were cheap compared to some of the other better quality options. I know that not everyone has the same budget for such things and not everyone uses their Jimny like I do but surely decent suspension to keep it shiny side up is a good idea?
Couldn't agree more.
The Black Raptor seems to be getting a lot of attention these days. But not a single person seems to be interested in where the shocks comes from. For all I know they could be the absolutely cheapest shocks possible to buy. Pro Comp, AVO and Rough Country are cheap shocks too, but at least we know a little bit about where they come from.
Jimnybits claims that the shocks are matched specifically to the Jimny. But I'm pretty certain they are no more matched to a jimny than RC or Pro Comps are.
- Thank you received: 653
You not need spring compressor just remove pan hard rod bolt and un-clip brake hose from chassis if neededGRAYWOLF wrote: Did you need spring compressors to fit this kit? and how easy was it..bearing in mind i am sat here longing to fit mine, but got no spring compressors at moment.!!
you may need help re-fitting pan hard rod (i used a ratchet strap)
Jack
