Power Steering Leak
  • slippy
26 May 2016 14:39 #167513 by slippy
Replied by slippy on topic Power Steering Leak
Additionally, the old union looked like it had been overtightened and the bottom of the thread stripped which was why I had difficulty in removing it.
I had to break off the horizontal section of the pipe - easy enough - and then I got a 17mm socket on it but it was still difficult to remove.
Anyway, all done and working as it should with no leaks.
  • Daniel30
26 May 2016 16:02 #167515 by Daniel30
Replied by Daniel30 on topic Power Steering Leak
Well done good result ;)
28 May 2016 15:42 - 28 May 2016 15:42 #167632 by kirkynut
Replied by kirkynut on topic Power Steering Leak
Good effort mate.
I think these jobs are made harder by the steering box etc being put in the car in the factory before the engine. They therefore leave the nut tightened at an angle where getting the spanner on it means the spanner hits something that wasn't there when it was fitted - like the alternator or something!
I had to do this on a Land Rover 90 and managed to get the open end of a spanner on the nut but not in a position where I could push it due to other gubbins in the way. I put a cable tie on the ring end of the spanner and was then able to pull the spanner round with quite a lot of force as cable ties are strong old things!
In theory it's such a simple job but then in practice these things are sent to try us!
Glad you got yours fixed with some good old ingenuity!
Last edit: 28 May 2016 15:42 by kirkynut.
  • barabas
28 May 2016 16:46 #167639 by barabas
Replied by barabas on topic Power Steering Leak
I've always thought that whatever it is you're working on was the first thing to go on the assembly line and the rest of the car was built around it!
I think it was an Astra where the bumper and a wheel had to come off to change the screenwash motor that was the most annoying, so far...
  • The Dug
30 May 2016 11:50 - 30 May 2016 11:52 #167712 by The Dug
Replied by The Dug on topic Power Steering Leak
That's a coincidence, came on to ask about the exact same problem.
I don't really use the jimny much now - my dad takes it when he's walking my dog but even that's not too often now.
I'm a bit embarrassed at how good the OP's looks compared to mine :blush:
I'll give the crowfoot sockets a go bit I'm worried that the nuts with just crumble.............
Last edit: 30 May 2016 11:52 by The Dug. Reason: Forgot to insert photos
  • slippy
31 May 2016 07:58 #167747 by slippy
To The Dug,
here is the receipt from the supplier with the dimensions of the union they made just in case you need it for a new part.
Once I had the new part it was quite a straight forward job.
I took a chance and also removed the high pressure pipe as well and did not need to bleed the system, but I don't think that is recommended.
Time to create page: 0.172 seconds
