Power Steering Leak
  • barabas
23 May 2016 22:26 #167346 by barabas
Replied by barabas on topic Power Steering Leak
Something like these " www.machinemart.co.uk/p/clarke-crows-foo...wrench-set-10-piece/ " I think - but the metric ones obviously :)
That should get you down there without dismantling anything. I get the impression that it wasn't a fun job but it was fairly cheap in the end.
--Phil
  • mickt
24 May 2016 18:16 #167392 by mickt
Replied by mickt on topic Power Steering Leak
You cannot get a lot of torque using them as they are designed for using a extension in the end so the drive line is down the extension and then transfers 90 degree to the union. Ok for running down a thread but no good for loosening a tight nut or final tightening.
  • barabas
24 May 2016 19:37 #167398 by barabas
Quite so but the torque setting for the high pressure side is 35Nm which isn't massive - I expect the low pressure side needs a bit less (no mention in the manual).
I didn't do this job myself but the chap who did was proud to show me exactly how he did it - no leaks since and that's proof enough for me ;)
  • slippy
25 May 2016 07:07 #167427 by slippy
Replied by slippy on topic Power Steering Leak
Phil,
I did see those crows foot spanners and will probably need to get something like that for reassembly. However, I need to source a new right angle end return pipe first. I am visiting some hydraulic suppliers this morning so hopefully should find something suitable. Wish me luck.
  • barabas
25 May 2016 08:36 #167434 by barabas
OK then, good luck with it:-)
  • slippy
26 May 2016 14:32 #167512 by slippy
All done. New end return was made and supplied by Anglia Hose & Hydraulics, Colchester for £16. Crows feet adaptors £18.
£34 quid and a couple of hours - all done.
Thanks for all the help.
Time to create page: 0.239 seconds
