Tyre Sizes - Rough Guide Thread
18 Apr 2015 18:37 #142730
by minibbb
Replied by minibbb on topic Re:Tyre Sizes - Rough Guide Thread
Mine have a -30 offset so stick out nicely! Do you have a lift?
The following user(s) said Thank You: Daniel30
- Nate83
- Visitor
20 Apr 2015 21:12 #142869
by Nate83
Replied by Nate83 on topic Re:Tyre Sizes - Rough Guide Thread
i got 2" spring spacers and 32mm wheel spacers
- Thank you received: 647
20 Apr 2015 21:41 #142872
Replied by Daniel30 on topic Tyre Sizes - Rough Guide Thread
Yeah it was minibbb jimny I was talking about looks good,the wheels and tyres your looking at should be fine I'm considering getting some soon after getting my lift sorted
The following user(s) said Thank You: minibbb
21 Apr 2015 11:31 #142893
by minibbb
Couple of better pics..... You've got these wheels already haven't you Daniel? Love the tyres! Went through some mud at the weekend that the grabbers wouldn't have coped with!
21 Apr 2015 12:09 #142896
Looking good.... Yeah I have probably get another set for the Goodrich then I can chop and change, did you have any problems with your insurance with the mt's on?
Cheers
Cheers
21 Apr 2015 12:53 #142897
by minibbb
No not at all mate- emailed flux about the lift and tyres and the premium didn't change!
Can't see why muds should put the price up- fully legal road tyres after all. Amazing as they don't feel any worse to drive on that the grabbers, not noisy or anything!
- Nate83
- Visitor
27 Apr 2015 19:08 #143263
by Nate83
Replied by Nate83 on topic Tyre Sizes - Rough Guide Thread
Awesome guys thanks for the advice,love the wheel/tyre combo you got there
03 Jul 2015 19:20 #147132
by furo
Replied by furo on topic Tyre Sizes - Rough Guide Thread
Very useful thread, thanks!
I have a standard Jimny and I don't plan to lift it. I'm going to get a set of all terrain tyres (most likely Goodyear Wranglers or Yokohoma Geolandars if that makes a difference) and so I need to decide between 205/70s or 195/80s. I like the idea of going for a larger tyre, but by my calculation the total increase in diameter is just one inch (correct me if I'm wrong!). I was just wondering if this makes any appreciable difference offroad or not? And are there any real negatives? I've read the post about correcting the speedo and reving a bit lower at higher speeds (which sounds good!) but I was wondering if there are any other issues.
Thanks (and apologies if hijacking this thread was the wrong way to ask this question - I just thought it seemed relevant)!
- Nate83
- Visitor
17 Jul 2015 14:03 #147870
by Nate83
my road tyres are 205/70/15 if that helps
29 Jul 2015 10:01 #148627
by fshdck
Jimny is not a car. It is a state of mind.
Replied by fshdck on topic Tyre Sizes - Rough Guide Thread
215/75 R15 Hankook MT RT03 initial experience.
Tires fitted on standard 15x5.5 steels, balanced easily between 40 and 80 grams per wheel.
Look very nice.
On standard, bit sagging 13 year old suspension there is no rubbing, even at flex but it's quite close. Anti roll bar wasn't removed.
Haven't done a lot off road driving yet, but the tires seem to perform good, no wheel spins on wet dirt tracks, gravel and grass at road pressures. Need to test them more extensively, but so far I'm happy.
Road noise is minimal, all I can hear is a little hum at motorway speeds, but the car is noisy anyway, and I might not be very sensitive to tire noise, so your experience may vary.
They handle excellent on dry tarmac, and surprisingly good on the wet too. The car wasn't pushed into extreme, but they seem be better on the road then budget road tires it came with.
Ride is noticeably softer due to tire size with 26/23 psi front/rear despite stiff sidewalls (tire is LT rated). Chalk test showed even wear of chalk at 22-21/20-19 psi, but it seems a little low for road use so I'm running 25/22 psi. Might drop the pressure down for heavy rain and winter. Lower pressures didn't seem to affect the handling apart from making the ride even more comfortable, and using a bit more fuel. After some more mileage I'll check the wear and maybe adjust the pressure then.
Fuel efficiency didn't suffer much, unless on lower pressures. I'd say it's 5-15% drop compared to 205/70R15 road tires, but it's a rough estimate.
Performance dropped, mostly due to up sizing. Not very noticeably at town speeds, but acceleration from 50 to 70mph in 5th gear takes ages. Cannot compare to road tires, cause I didn't drive on motorways while having them on the car. Braking seems to be unaffected.
Conclusion: not really MT tire, more like aggressive AT, grippy, quiet and comfortable. Winter performance might be sketchy due to lack of siping, time will tell. I'm having high hopes for them to make a decent all season tire cause rubber compound is pretty soft, but it's too early to draw such conclusions yet.
Look very nice.
The following user(s) said Thank You: Chezzy71
29 Jul 2015 10:08 #148629
Very nice, nice little write up too
30 Jul 2015 06:49 - 30 Jul 2015 07:02 #148669
by fshdck
Not many people have them here, or don't write about it. I bought them thinking of a cheaper alternative to BFG muds, after reading positive reviews from US and Germany.
Surprisingly the German tire vendors publish an EU label, which for this size is: fuel D, wet grip C, noise 73dB. Whether the EU labels can be trusted might be questionable, but it's better then most AT tires.
Another pic:
Another pic:
Last edit: 30 Jul 2015 07:02 by fshdck.
Time to create page: 0.306 seconds
