Tyre Sizes - Rough Guide Thread
- 1066Boy
18 Oct 2016 15:54 #173712
by 1066Boy
Replied by 1066Boy on topic Tyre Sizes - Rough Guide Thread
One thing worth mentioning is the diffence between standard tyres and remoulds.
My tyres are remould Muds in standard size (205/70)
Even with my 2" lift they only just fit and I still had to remove the mudflaps !
19 Oct 2016 10:40 #173735
by Bosanek
Replied by Bosanek on topic Tyre Sizes - Rough Guide Thread
Good point. I have added that to my document and to the wiki.
The following user(s) said Thank You: 1066Boy
- Maher
24 Nov 2016 22:38 #174891
by Maher
Replied by Maher on topic Re:Tyre Sizes - Rough Guide Thread
Hello Guys, hello Nate,
I have a question, I bought from jimny bits a 2" body lift and wheel spacers and 215 -75 / 15 Bfgoodrich tires, but I was told by my mechanic that the body lift will affect the factory ride quality and the ride will become stiffer on roads, even though the website says other wise, I wanted to know since you have the same lift if the rides stiffens and handling is affected, my jimny is a daily driver and I ocaisionaly take it off-road.
Thanks
Thanks
24 Nov 2016 22:49 #174892
Replied by jackonlyjack on topic Re:Tyre Sizes - Rough Guide Thread
the body lift will not change anything
i suppose it will be 2" taller and effect the COG a tiny bit
the ride will feel the same i am sure
Jack
p.s maybe your mechanic just doesn't want to do it so trying to put you off
Jack
15 Dec 2016 15:54 - 16 Dec 2016 14:07 #175688
by Bosanek
I am informing the public that I have finished all my additions to the Wiki article about tyre sizes, models and best usage practices.
The article is located here:
www.bigjimny.com/mediawiki/index.php/Tyr...age_-_best_practices
I consider that article 98% finished.
Part of the content of that article (the last three chapters) is replicated in another wiki article about improving and modifying Jimny for mixed on-road and off-road use: www.bigjimny.com/mediawiki/index.php/Imp..._and_all_terrain_use
By the way, that article is also 98% finished as far as I am concerned.
Last edit: 16 Dec 2016 14:07 by Bosanek. Reason: Link correction
16 Dec 2016 14:08 #175709
by Bosanek
Well it ain't over until it's over.
After sleeping it over last night, I had some more ideas and some refinements to add. So now those should finally be (almost) finished.
Time to create page: 0.288 seconds
