What battery are you using?
- Thank you received: 2
What are you lot using?
Used it about 3 times in a few hours to winch at my local club recently, no problems.
It's ideal for simple recovery. For competitions I'd look at perhaps 2 of them and a second alternator.
You can get about 2 of them for the price of one of the popular winch batteries.
i know nothing about batterys, is there a model number or anything for the size dimensions i need?
i will eventualy get two of them, but the first will br a direct replacment for the standard,
also, will the standard battery terminals fit onto the Numax 1000a ?
sorry for all the quesrions, i just want to get it correct first time.
www.tayna.co.uk/Numax-Leisure-Batteries-S284-1.html
and Tanya are the people the get them from - first class service and delivery times.
As you can see from the dimensions in the spec it will not fit in your normalbattery tray so will need re-locating to the boot and you will need to get some very heavy duty cable to run on top of the chassis, attached by cable ties (I like cable ties) and bring it in via the drain hole in the boot.
You will also need some big terminals and a big crimper to attach them to the wires.
See here:
www.vehicle-wiring-products.eu/VWP-onlin...ble/batterycable.php
you want 50mm sq cable and these connectors - the CTT50's:
www.vehicle-wiring-products.eu/VWP-onlin...conns/batttermls.php
Place your winch and solenoid in roughly the right place and run string where you are going to route the wire, cut it and measure how much you used. That plus a bit extra is how much wire you need to order.
This solenoid extention kit is really useful too:
www.winchsolutions.co.uk/index.asp?actio...ts&catid1=1&catid2=4
but I have heard their isolators aren't up to long winch pulls.
Hope this helps
cgi.ebay.co.uk/car-battery-cut-off-switc...&hash=item519096f08d
I got it at a local car parts shop for £5.99 as it was recommended by a good few people in my club who use them and have used the key types and melted them but have not yet melted one of these.
I does not come with any specs on the packaging so I just had to trust my recommendations and so far so good! I ought to carry a spare though in case I do have a problem.
theres a small problem of me mounting it in the boot
ill make a new battery tray on the passenger side of the engine bay,
ive already got a heavy duty isolator switch and the extended solenoid cables,
just need to get it all in and working and make up a loom to have in-cab controls to the winch
- darthloachie
- Visitor
darthloachie wrote: someone's stolen the back! are you going to make it into a pick up or a tray back?
Tray Back! Tray Back! Tray Back! Tray Back! Tray Back! Tray Back!
I realy want to see a Tray back Jimny!
You've got lots of space for lots of batteries then wherever you design them to be!
- Nelson83
- Visitor
