BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
clunk!
  • Skinhead
  • Visitor
  • Visitor
27 Apr 2013 22:02 #69574 by Skinhead
clunk! was created by Skinhead
My jimny is making a clunk noise when setting off/accelerating and when taking foot off accelerator, i think its coming from the rear. Any ideas what it could be? Its got new wheel bearings on both sides so dont think thats the problem.
  • bazzab
  • Visitor
  • Visitor
27 Apr 2013 22:22 #69577 by bazzab
Replied by bazzab on topic Re: clunk!
Have the same thing bud. So be interested in replys.
  • UKDAN
  • Visitor
  • Visitor
27 Apr 2013 22:36 #69582 by UKDAN
Replied by UKDAN on topic clunk!
Rear diff ? LR Freelanders are known for that symptom, just a thought.
Dan
27 Apr 2013 22:56 #69587 by gus2000
Replied by gus2000 on topic clunk!
Hi, many suzukis have a excessive backlash between teeth of planetary and satellites of diff.
In my Jimny the solution showed up when changing the rear differential by new one (ARB locker)
The "clanck" was solved definitively
Also check cardanic joints, homocinetic joint, and ajust between ring and gear of differential.
Success
Gustavo
Gustavo LU2HC - Rio Cuarto (Argentina)
Jimny 1999 - 1.6 16V - SOHC
  • mudman
  • Visitor
  • Visitor
27 Apr 2013 23:17 #69589 by mudman
Replied by mudman on topic clunk!
iv just solved the same problem check your radius arm bolts mine were loose and make shure the hole havent elongated mine have started
  • markyp2000
  • Visitor
  • Visitor
28 Apr 2013 07:27 #69593 by markyp2000
Replied by markyp2000 on topic clunk!
Gear box mount. transfer box mount. prop shaft joint. Engine mount. The nut loose be hind the wheel
28 Apr 2013 09:58 #69601 by mlines
Replied by mlines on topic clunk!
1. Universal Joint Worn
2. Axle arm bolts loose
3. Axle arm mount worn/broken.
  • bazzab
  • Visitor
  • Visitor
28 Apr 2013 11:11 #69607 by bazzab
Good heavens just a few things then Hahaha. Best i get under and have nose.
28 Apr 2013 19:38 #69657 by Johnniehec
Replied by Johnniehec on topic clunk!
mudman wrote: iv just solved the same problem check your radius arm bolts mine were loose and make shure the hole havent elongated mine have started
Yup, mine too. Tightened them up but it's returned again.
John.
  • Skinhead
  • Visitor
  • Visitor
30 Apr 2013 20:46 #69767 by Skinhead
Replied by Skinhead on topic clunk!
Cheers guys, tightend up the radius arm bolts yesterday an it seems fine now :)
  • ozjoel
  • Visitor
  • Visitor
01 May 2013 10:50 #69800 by ozjoel
Replied by ozjoel on topic clunk!
John.
loctite works wonders.
get the high strength stuff.
  • GuardianAngel
  • Visitor
  • Visitor
01 May 2013 11:17 #69802 by GuardianAngel
Replied by GuardianAngel on topic Re: clunk!
I get this as well. Will try my radius bolts as well.
Time to create page: 0.117 seconds
Powered by Kunena Forum
