Castor correction.... Help/advise??
- Thank you received: 584
What you need is a polybush kit, these go in with your fingers.
Stand car on level surface, handbrake on.
Work on one side at a time.
Undo the nuts on the 3 large bolts. (This is V difficult, as suzuki put the nuts on the inside. Undoing the bolts is even more so. There isn't enough room to use the Landrover trick of a 12foot scaffold pole over the end of the breaker bar) tap the bolts out, and the arm will drop down.
Replace the arm. You may need to chock the front wheel each side, and release the handbrake, then rock the car to get the last bolt to line up. Some folks use one of those ratchet straps to pull the axle.
- ferreter
- Visitor
thank you, very helpful. thats a shame, i will try and see if i can get them out in resonable condition, of not look like another 80 odd quid on a polybush kit!facade wrote: You won't get the old bushes out and in the new arms in good condition.
Undo the nuts on the 3 large bolts. (This is V difficult, as suzuki put the nuts on the inside. Undoing the bolts is even more so) tap the bolts out, and the arm will drop down.
- Thank you received: 210
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- ferreter
- Visitor
ookay, will do that. dammit, im annoyed with myself now! should of asked this before i ordered! thank you everyone for you helpdirtydogz wrote: Just save up the money and buy them later, using old bushes is false economy and if you can't get them out in one piece then your jimny won't be going anywhere.
- renard38
- Visitor
- Goat
- Visitor
- Three glasses
- Visitor
Just go to www.polyurethane.ru and find Jimny's ones. Contact them, they understand English. Shipment to UK will cost You some 10-20 poinds, no more.
All Russian Jimny lifters use this optimal way. I'm driving mine for the last 50 t.km - still alive. The car rides 35" TSL Boggers, used for trophy only.
- reaper
- Visitor
- Three glasses
- Visitor
E.g. mine is 85 mm and the car is still self-steering. And in any case it's easier and simplier to blow off the axle bracket by plasma or just cut it by wheel and to weld it back with 2-3 deg. angle.
- ferreter
- Visitor
cheers
- renard38
- Visitor
Just go to www.polyurethane.ru and find Jimny's ones. Contact them, they understand English. Shipment to UK will cost You some 10-20 poinds, no more."""
it is written in Russian! i don't understant nothing
- MWells
- Visitor
renard38 wrote: ""
Found by luck more than Russian language skills. Search jimny in the top left of the page, i did have a link but couldn't post it as BJ thought it was spam.
Mark
