A quick volt meter install project
Knowing the coolant temperature to the degree is great as the gauge doesn't move much on the dash.
It will.give an early indication of overheating, battery or alternator trouble.
Not as cheap though but can show and clear trouble codes so is a really useful bit of kit.
- JerseyJimny
- Visitor
- Mud_Muppet
- Elite Member
- Thank you received: 7
kirkynut wrote: I've got a scan gauge like what Martin has and have it permanently connected to the ecu. I can see volts and engine temp in celcius along with rpm and speed in kph which are less useful.
Second that I've got a Scan gauge as well it's a bloody good bit of kit !!! Would recommend to anyone to get one !!!
2001 Red Tin Top,
4.5 inch ORA lift kit,
Pro Comp steering damper
Kap Winch Bumper,
White Weller offset Rims with 30" Insa Turbo Special Tracks,
CB Radio,
Stripped Interia
Roof Rack with 4 front Wipac,
Rear Wipac recovery Lights
.....Plenty more on its way !!!!
- Dutchjimny
- Visitor
- JerseyJimny
- Visitor
- Thank you received: 210
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
- JerseyJimny
- Visitor
