k&n filter
- SUGAR DELTA
- Visitor
will it really improve thing's??
Cheers
- myers647
- Visitor
- Keefe
- Visitor
Just saves a little on buying standard filters, IF you're keeping the vehicle long term.
A little filter cleaner and filter oil, job done.
As far as an increase in performance, did you say you were fitting it in your Veyron or Jimny?
Jim isn't powerful enough for you to notice any gains.
BUT, I wouldn't fit one to my Merc as I want to keep that long term and MAS's are expensive. LoL!
- SUGAR DELTA
- Visitor
They aint too expensive,found them for £26 delivered on flea-bay but if they do absolutely nothing to improve anything I may not bother.
Let's see.
Because I plan to keep this baby long term
- Jeffskowski
- Visitor
- ZookFastback
- Visitor
- Jeffskowski
- Visitor
ZookFastback wrote: Anyone considering fitting a K & N Filter should check out this site first... www.bobistheoilguy.com/airfilter/airtest1.htm and if you already have one of those filters, toss it out and spend the money on a quality paper filter.
In 20 years of motoring I have never seen any damage of engine components or running issues when using serviceable air filters. From VW beetles with HiPo engines to the modern daily run around, I have always used them and not once have I had an issue.
It's entirely up to the driver what they choose of course but this is my experience.
There is a lot of test data out there for every single thing that has ever been produced. Lots of positive and lots of negative. I am not disagreeing with what Oily Bob is saying in his testing but it is just one opinion.
- stu44
- Visitor
- SUGAR DELTA
- Visitor
Thanks to all that replied !
- Thank you received: 584
stu44 wrote: i have a k&n panel filter on my jimny and i have found i get approx 10 mpg better,hope this helps
What 40 + with a K&N?
I'm gonna fit 3 then, I want 60MPG
- darthloachie
- Visitor
I have two fitted but still only get 20-25mpg
