BigJimnyMeet 2024
i need help: what is this noise ( from a pulley )
- renard38
- Visitor
26 Jun 2011 17:36 #18290
by renard38
i need help: what is this noise ( from a pulley ) was created by renard38
hi
i have changed the viscous coupling, but noise again Have you got ever the same?? Where it's comes from???
A+
A+
- Thank you received: 584
26 Jun 2011 19:53 #18300
by facade
Replied by facade on topic Re: i need help: what is this noise ( from a pulley )
Take off the belt for the power steering, by slackening the bolts through the adjuster and see if it is still noisy.
If it is, it may be the alternator bearings, water pump, or even just a worn out fanbelt, or one that needs retensioning.
If it isn't, it may be the tensioner pulley, steering pump or again a worn out drive belt.
- renard38
- Visitor
27 Jun 2011 09:21 #18311
by renard38
Replied by renard38 on topic Re: i need help: what is this noise ( from a pulley )
yes, i would do this yesterday in the woods, but i haven't enough tools with me
this afternoon i go at suzuki dealer in order to see if i can drive with this noise during my holliday ( 2 weeks ) and i'll repair after.
- panosd
- Visitor
27 Jun 2011 11:21 #18315
by panosd
Replied by panosd on topic Re: i need help: what is this noise ( from a pulley )
It's not a big deal. Just go to a suzuki service and ask them to tight up your 2 belts between the fan and the
engine. It takes about 5 minutes to do both.
Its easy for them to do that because of a special tool that they have for this job.
- renard38
- Visitor
27 Jun 2011 16:07 #18322
by renard38
the belts don't slide on the pulley.
I have see suzuki dealer and they told me the only methode is to put a belt after another. That of the alternator and then the power steering .
- panosd
- Visitor
27 Jun 2011 16:48 #18323
by panosd
I had the same problem in the past and that was the solution. I ask me friend at local suzuki and he told me
the same for what i asked him and explained him.
Do you have install the proper belt? The width is ok?
If you have done this , then the only thing left is to make it tight.
- renard38
- Visitor
27 Jun 2011 16:57 #18325
by renard38
yes, i have installed the good proper belt; and The width is ok.
28 Jun 2011 08:04 #18351
by Obarno
Replied by Obarno on topic Re: i need help: what is this noise ( from a pulley )
It sounds like a belt - try putting a little chalk dust onto the belt and if it stops the squeaking you have found the problem.
To make sure its not the alternator, water pump, power steering pump, idler pulley etc take a long handled screwdriver and place it (carefully) on each item and listen to the noise - like a stethoscope. You will quickly hear if a bearing is going on something.
- renard38
- Visitor
28 Jun 2011 18:36 #18369
by renard38
i have ever taked a long handled screwdriver and place it (carefully) on each item and listen to the noise: all is ok, no strange noise
- panosd
- Visitor
29 Jun 2011 08:29 #18381
by panosd
Take off the 2 belts and apply on them a small amount of vaselini in order to make them soft.
The squising noise will stop.
29 Jun 2011 10:43 #18384
by Obarno
It definitely sounds like the belt then. An easy way is to spray a little WD40 onto the belt whilst the engine is running - one at a time if you can. The noise will disappear if its the belt.
- renard38
- Visitor
29 Jun 2011 16:58 #18408
by renard38
no, no it's not the belts; There is a big difference when a belt slide.
on this vidéo, you can hear the belts (belt not slip but is too dry; changed now ):
This afternoon, i controlled the pulley dumper: OK
I then put a single belt (that of the alternator and water pump), there was a very slight noise which increased when I turn the headlights, so maybe the alternator ...
Time to create page: 0.120 seconds
