BigJimnyMeet 2024
× A place for more technical discussions. Please make sure you post in the correct section on the site, this way it keeps the site tidy AND ensures you get a more relevant answer.
SUSPENSION/TYRE/BODY LIFT
  • chechan rebel
  • Visitor
  • Visitor
24 Mar 2011 07:32 #13938 by chechan rebel
SUSPENSION/TYRE/BODY LIFT was created by chechan rebel
I have a question regarding this, im bout to buy a suzuki jimny 2001 model completely stock. I want to put a 80mm lift kit in + 30"x9.5"x15" tyres + 15"x7" sunraiser rims..........Will these scrape? If so..........what about if i also lift body another 2"? If i lift body is there anything else i need to modify, gear shift, 4wd shift, steering? Any help be apressiated....:cheer:
  • vitara_mad
  • Visitor
  • Visitor
24 Mar 2011 09:58 #13949 by vitara_mad
Replied by vitara_mad on topic Re: SUSPENSION/TYRE/BODY LIFT
when i got mine it had a 3" susp lift & 30x9.5 tyres & they was fine with just a little arch trimmed
if you do a 2" body lift you will need longer brake hoses & you will need to do a slight adjustment on the transfer lever (thats all i had to do on mine anyway)
  • viciouspenguin
  • Visitor
  • Visitor
24 Mar 2011 10:05 #13951 by viciouspenguin
Replied by viciouspenguin on topic Re: SUSPENSION/TYRE/BODY LIFT
you'll also need to extend the steering column if you lift the body.
  • biggaz
  • Visitor
  • Visitor
24 Mar 2011 12:55 #13953 by biggaz
Replied by biggaz on topic Re: SUSPENSION/TYRE/BODY LIFT
you will need hoses anyway with a lift above 50mm
  • vitara_mad
  • Visitor
  • Visitor
24 Mar 2011 15:58 #13960 by vitara_mad
viciouspenguin wrote: you'll also need to extend the steering column if you lift the body.
ive not had to extended the steering colum on mine so it maybe a case of some you do & some you don't
  • adamjimny
  • Visitor
  • Visitor
24 Mar 2011 16:10 #13962 by adamjimny
Replied by adamjimny on topic Re: SUSPENSION/TYRE/BODY LIFT
i haven't either
  • srcars
  • Visitor
  • Visitor
24 Mar 2011 19:38 #13985 by srcars
Replied by srcars on topic Re: SUSPENSION/TYRE/BODY LIFT
2003 soft-top, just fitted 2" body lift and steering column was 25mm short and transfer lever wont quite go into 4wd low, Brake splitter block needs a new bracket, Everthing else ok, fuel filler ect.
  • chechan rebel
  • Visitor
  • Visitor
24 Mar 2011 23:52 #14009 by chechan rebel
Replied by chechan rebel on topic Re: SUSPENSION/TYRE/BODY LIFT
i haven't either
Cheers for the replys................steering & shift wont be difficult as im a welder/ fabricator. Ile have to find some longer brake lines, how much longer do they need to be?
  • vitara_mad
  • Visitor
  • Visitor
25 Mar 2011 01:42 #14011 by vitara_mad
if you doing 3" susp & 2" body lift then +5" brake hoses will be needed
  • chechan rebel
  • Visitor
  • Visitor
25 Mar 2011 01:48 #14012 by chechan rebel
Cheer bro........basically every inch you put in you gotta add an inch.
  • biggaz
  • Visitor
  • Visitor
25 Mar 2011 12:18 #14044 by biggaz
yeh, see Martin for extended hoses :-)
  • Monkey
  • Visitor
  • Visitor
26 Mar 2011 08:44 #14079 by Monkey
Replied by Monkey on topic Re: SUSPENSION/TYRE/BODY LIFT
Hey mate,
Have a read of this read thread www.auszookers.com/index.php?name=Forums...opic&t=18611&start=0
Also have a look a around that site, heaps guys from you state that are into zooks and go on trips.
Time to create page: 0.130 seconds
Powered by Kunena Forum
