Jimny LCV - Wheel/Tyre size question...
- Thank you received: 457
20 Jul 2024 22:59 #256868
Replied by DrRobin on topic Jimny LCV - Wheel/Tyre size question...
I found your Jimny on Autotrader, the tyres look very big, check the inside of the front wheel arches for rubbing and/or try it lock to lock, get out and check clearance.
Also I cannot see any front hubs (these come through the front wheels), it looks like these have been removed to fit the wheels, ask the seller how the front wheels engage or disengage? It might not have any front wheel drive or might be permanently locked, neither is desirable.
If the seller has messed with the 4WD just to fit these stupid alloys I would walk away.
Given the mileage and accessories (roof rack, snorkel) it looks a bit on the cheap side to me, especially as Suzuki have just stopped importing the Jimny.
Finally I can’t see any genuine Suzuki garage fitting this wheel/tyre set up, it would probably invalidate the warranty, it looks more like a home fit.
Robin
Robin
The following user(s) said Thank You: richythepom
- Thank you received: 610
20 Jul 2024 23:39 - 20 Jul 2024 23:40 #256869
by facade
Replied by facade on topic Jimny LCV - Wheel/Tyre size question...
I've seen the blue one on autotrader, they don't look like 18" wheels to me, but I could be wrong, the photos aren't very good.
Looks a good price compared to the others, I'd get it and change the wheels to 15" or even 16" (and swap that towbar for a detachable, or wear greaves I suppose )
Last edit: 20 Jul 2024 23:40 by facade.
- richythepom
- Thank you received: 1
21 Jul 2024 09:55 #256876
by richythepom
Replied by richythepom on topic Jimny LCV - Wheel/Tyre size question...
Thanks for the tips DrRobin - I'll make sure to do those checks
- richythepom
21 Jul 2024 09:57 #256877
by richythepom
Thank you Facade. The seller confirmed he'd made a mistake - the tyres are in fact 16" (235/70 R16)
- Thank you received: 27
21 Jul 2024 13:41 - 21 Jul 2024 13:47 #256880
by Motacilla
IMO, asking the seller if the front drive has been removed qualifies as a "silly question." Nobody anywhere has deleted the front drive on a Jimny to fit alloys. Let's try to keep our advice to the newbies a little more grounded.
My personal recommendation, Richy, is that you do not buy a Jimny without driving one first -- really driving it, for miles, on the motorway and around town. You may be surprised at how different it is from most any other car on the market. And not pleasantly surprised: many who bought the Gen4 Jimny on the basis of its cuddly looks later popped up here to complain about its lack of motorway manners, relatively poor fuel mileage, primitive ride, etc.
A Jimny is a great little car for a specific purpose. Be sure you are looking for something to fill exactly that purpose before you buy one.
Replied by Motacilla on topic Jimny LCV - Wheel/Tyre size question...
The wheels have caps over the hubs.Also I cannot see any front hubs (these come through the front wheels), it looks like these have been removed to fit the wheels, ask the seller how the front wheels engage or disengage? It might not have any front wheel drive or might be permanently locked, neither is desirable.
Last edit: 21 Jul 2024 13:47 by Motacilla.
- richythepom
21 Jul 2024 14:07 #256882
by richythepom
Thank you Motacilla, I appreciate your input. Yes, I've taken the opportunity to test-drive the model I'm planning to purchase.
TBH, it's largely for my daily runaround (not planning any big motorway miles etc. - we have a family car more suited to that).
I'd also like to have a play off road and learn how to use this functionality properly, in case ever really needed...
21 Jul 2024 14:25 #256883
by Motacilla
In that case, rock on.
The Jimny is as good offroad as it is bad onroad. It's a great vehicle to learn offroading with because of the wieldy size and weight, and nothing on it costs more than five quid.
It's like a 2/3-scale Series Landie except that it always starts and the pieces don't fall off. But like the Landie, it needs a certain mindset.
I hope you get a good one, and enjoy it.
- Thank you received: 1801
21 Jul 2024 18:35 #256886
If we are all looking at the same car on autotrader then I agree that it looks to have caps on the front wheels the are far too small to allow for the vacuum hubs to be present. I definitely wouldn't put it past people to put aesthetics before practicalities and often safety, I have met members of the public before.
Replied by Lambert on topic Jimny LCV - Wheel/Tyre size question...
21 Jul 2024 19:31 - 21 Jul 2024 19:32 #256887
by Motacilla
I'm looking at this one. The wheels are the Gunner model from Black Rock.If we are all looking at the same car on autotrader then I agree that it looks to have caps on the front wheels the are far too small to allow for the vacuum hubs to be present.
Last edit: 21 Jul 2024 19:32 by Motacilla.
21 Jul 2024 20:25 #256890
by facade
The easy way to tell if the hubs are present is to start it up and let it idle, turn the air con & radio off, stop the salesman talking, open the drivers door and pull the transfer lever back into 4wd.
The hubs will go "clackclack" as they engage if they are present & working. (The 4wd light comes on after a couple of seconds)
Wait a few seconds to make sure there is plenty of vacuum in the tank and push the transfer into 2wd. The hubs will give a softer "clickclick" as they disengage.
I'd be more concerned about cracking my shins on that towbar, it would definitely have to go.
TBH, I'd expect wheels for a 4x4 to accommodate the front hubs, likely that cap is thin plastic. The wheels look to have more offset than standard too.
- Roger Fairclough
- Thank you received: 210
21 Jul 2024 21:28 #256891
by Roger Fairclough
Replied by Roger Fairclough on topic Jimny LCV - Wheel/Tyre size question...
The rim edge certainly looks as if it is in line vertically with the wheel trim and that means it is approx. 25 mm further out than standard. I would suggest the car is fitted with wheel spacers and that would probably be enough to allow the fitting of those hub covers.
Roger
Roger
The following user(s) said Thank You: Motacilla, richythepom
22 Jul 2024 03:30 #256892
The problem is that without the seller taking the wheel off this is all speculation and as a buyer I would not be wanting to find out after I had bought the car. Caveat emptor and all that. Yes it might be fine but just as likely it might not especially with the oversized tyres and other stuff done to it it might all be correct ot it might all be held on with double sided tape. Other people's problems.
