UK mot test?
- Thank you received: 324
17 Jan 2024 14:50 #253560
by Gadget
Replied by Gadget on topic UK mot test?
Had my MOT today, no advisories, however lowest tread depth on my tyres was 8.4mm, so not exactly borderline!
At this rate they'll get failed for age before tread depth.
- Thank you received: 1801
17 Jan 2024 15:55 #253561
Replied by Lambert on topic UK mot test?
This is my problem and I'm not sure if I buy good expensive replacement ones or cheaper faster wearing ones more often?
- Roger Fairclough
- Thank you received: 210
17 Jan 2024 16:20 #253562
by Roger Fairclough
Replied by Roger Fairclough on topic UK mot test?
All of which comes back to my original point that testers are under pressure to conform to averages or they face consequences and therefore now more than ever they are nitpicking really minor things on otherwise sound vehicles to cover themselves.
"Consequences". Now you are sounding like the Post Office. Yes, if there is a fault they should find it, but if no fault exists, statistics or not, they must pass it.
Roger
17 Jan 2024 18:00 #253563
Apparently and this is second hand information but allegedly falling foul of an investigation can carry a custodial sentence. OK if you are being too lenient and passing stuff that shouldn't be on the road fair enough but if that's the potential outcome of getting on their radar then you can quite see that affecting how people do their work.
- Thank you received: 16
18 Jan 2024 17:31 #253577
by Phaeton
Replied by Phaeton on topic UK mot test?
They do prosecute testers movingon.blog.gov.uk/2022/05/12/mot-frau...risk-to-road-safety/ but 1300 fraudulent tests (discovered) in 30,000,000 carried out isn't a lotApparently and this is second hand information but allegedly falling foul of an investigation can carry a custodial sentence. OK if you are being too lenient and passing stuff that shouldn't be on the road fair enough but if that's the potential outcome of getting on their radar then you can quite see that affecting how people do their work.
18 Jan 2024 20:42 #253578
by Pondboy
Replied by Pondboy on topic Re:UK mot test?
Out here in Spainland The ITV (MOT) is performed by a government agency via a drive through test where after booking online you drive through a number of bays to have an emissions test, headlights adjustment test, then all lights test, rolling road brakes test, suspension and linkages test, along with seatbelts and tow bar lights test if not previously done.
All in all about 1/2 hour & 48 euros with a 2 week notice to correct failed items.
PB
Sent from my IN2013 using Tapatalk
PB
- Thank you received: 457
18 Jan 2024 20:52 #253579
I suppose only low profile (smaller tread depth when new) or high mileage cars wear out the tread before the tyre ages too much.
Robin
Replied by DrRobin on topic UK mot test?
Tyres only seem to last 4 or 5 years before the rubber hardens and starts to crack. You can get a lot longer if you keep them out of the sun, e.g. in a garage. It must be even worse in sunny countries.Had my MOT today, no advisories, however lowest tread depth on my tyres was 8.4mm, so not exactly borderline!
Robin
18 Jan 2024 21:20 #253580
by Phaeton
Replied by Phaeton on topic Re:UK mot test?
That's similar to the HGV test in the UK, when we used to have a 7.5T horsebox I was always happy to go as you knew it would be an unbiased test,Out here in Spainland The ITV (MOT) is performed by a government agency via a drive through test where after booking online you drive through a number of bays to have an emissions test, headlights adjustment test, then all lights test, rolling road brakes test, suspension and linkages test, along with seatbelts and tow bar lights test if not previously done.
PB
- Roger Fairclough
19 Jan 2024 13:55 #253583
by Roger Fairclough
Replied by Roger Fairclough on topic Re:UK mot test?
As a member of the Birmingham University Motor Club, I looked after the students union walk through panel van and that required an HGV test because of it's weight. The test was brutal and involved a 4ft crowbar on the suspension.
Roger
Roger
Time to create page: 0.140 seconds
