225/80r15 tyres
- CharterBoat
04 Mar 2022 23:29 #242146
by CharterBoat
225/80r15 tyres was created by CharterBoat
Hey, I was just wondering if anyone runs 225/80r15 tyres on their gen 3 with a 2inch lift? and what offset are you running aswell?
05 Mar 2022 21:37 #242154
Replied by yakuza on topic 225/80r15 tyres
On my gen 3 with 2" lift and 235/75/15 the best option to "clear" the original and unmodified fenders is to use the original wheel offset. I use the original alloys. there will be rubbing.
I would think that with your tire size it would be the same.
- CharterBoat
06 Mar 2022 00:13 #242156
by CharterBoat
Replied by CharterBoat on topic 225/80r15 tyres
as soon as i posted this question i realised that there arent many tyres in the size i mentioned. see i would like to go 235s but from my understanding the stock wheels arent wide enough for the 235s, have you had any problems with the stock alloys?
06 Mar 2022 22:27 #242169
by Busta
Replied by Busta on topic 225/80r15 tyres
Stock rims are fine for 235 tyres.
- Roger Fairclough
- Thank you received: 210
07 Mar 2022 09:26 #242173
by Roger Fairclough
Replied by Roger Fairclough on topic 225/80r15 tyres
225/75R15 need minimum 6" rim and 235/R15 need minimum 6.5" rim.
Roger
Roger
- Thank you received: 1811
07 Mar 2022 10:39 #242174
Replied by Lambert on topic 225/80r15 tyres
There's no hard and fast rule on this, it's down to the manufacturer of the tyre in question to stipulate the minimum and maximum wheel size for each size and model of tyre they provide. They are supposed to publish this information under law but it's invariably very well hidden.
07 Mar 2022 11:15 #242176
by 300bhpton
I've never really seen tyre makers have different rim specs though for a given tyre width. I'm not saying you shouldn't run wider than recommended, but it should be done so with the knowledge that you are probably breaching Construction & Use regulations and that to the strictest letter of the law it could make you vehicle not fit for road use and also cause potential issue with insurance should you be in an RTA/RTI.
Chances are remote that it would be an issue. But the possibility would always be there.
Replied by 300bhpton on topic 225/80r15 tyres
The BFG site is quite good for this (the US one, not the UK one).There's no hard and fast rule on this, it's down to the manufacturer of the tyre in question to stipulate the minimum and maximum wheel size for each size and model of tyre they provide. They are supposed to publish this information under law but it's invariably very well hidden.
07 Mar 2022 11:26 #242177
by Busta
Roger, those sound like the generic figures given for standard and low profile tyres. With the tall sidewall of the tyre size in question it will safely fit a lot broader range of rim sizes. Also for off-road use it is preferable to keep the rim width as narrow as possible to protect the bead and the sidewall. As an example, BFGoodrich reccomend a 6"-7" rim for their 235/75r15 tyres.
From experience, tyres as wide as 10.50 (260) are fine on the standard 5.5 rims.
07 Mar 2022 12:47 #242178
The in sewer ants would probably try it on if you have anything other than factory spec if you haven't told them as they just love to find a way out of paying a claim. It's part of the reason I don't have a massive amount of modified parts on Temeraire, because even when notified those you oily swine will try anything.
- Roger Fairclough
07 Mar 2022 14:34 #242180
by Roger Fairclough
The info. I have given was taken from a Goodyear booklet entitled "Light truck, van and 4x4 tyre data and maintenance" and is based on info. from the "Tire and rim association standard".
Tyre manufacturers will specify the recommended rim size and also the permitted rim size. If these limits are exceeded then the tyre tread will attempt to conform to the designed tread pattern and this will cause unnatural and dangerous wear patterns to emerge. The relationship between tyre width and rim size is part of the design and is paramount to the safe use of the tyre.
Roger
Roger
07 Mar 2022 15:09 #242181
The relevant body that we are under is etrto the European tyre and rim technical organisation which is useful to know of itself but also a little pointless as it's a trade members only body not a public one unfortunately.
- Roger Fairclough
07 Mar 2022 16:10 #242182
by Roger Fairclough
Charter Boat is probably confused that there are so many people giving him different answers to his question, so I would suggest he asks Suzuki to give him a definitive answer to the suitable sizes for his rims.
CustomerServices@suzuki.co.uk
Roger
Roger
Time to create page: 0.159 seconds
