E10 petrol
- Adrian
- Visitor
01 Sep 2021 07:09 #238090
by Adrian
E10 petrol was created by Adrian
HI All, I have a 54 plate gen3 jimny will it be ok running on the new E10 petrol?
I looked on the ukgov web site but it's as useful as slicks in snow.
Thanks Adie
Thanks Adie
- Axholme Lion
- Visitor
01 Sep 2021 07:11 #238092
by Axholme Lion
Replied by Axholme Lion on topic E10 petrol
I have a 20 plate and E10 will be going nowhere near it.
01 Sep 2021 08:48 #238094
Replied by mlines on topic E10 petrol
Suzuki have confirmed that E10 is fine in the Gen3 and Gen4 Jimny, Take a look in the owners manual.
- Thank you received: 923
01 Sep 2021 16:26 #238122
Replied by X8GGY on topic E10 petrol
Checked my Mum's57 plate Suzuki SX4 manual today, and her's is fine too...
- Thank you received: 434
01 Sep 2021 22:10 #238136
Replied by DrRobin on topic E10 petrol
My 2011 Jimny and 2001 other car are both E10 compatible, but here is the thing my other car has developed a small misfire at low revs and after deceleration after filling up with E10. My Jimny also seems to be running slightly different.
I filled my other car up at a different garage and suspect fuel contamination, so it has now been refilled at my usual garage and for good measure a bottle of Redex Advanced thrown in. It is running a bit better so will see how it goes and then might switch the Super Unleaded.
I put a bottle of Redex in the Jimny as well, I might try Super Unleaded in that just to see if it makes any difference and if it runs better or does more mpg might stick with Super Unleaded.
Going up a long steep hill in my Jimny tonight, I managed to get it to hold top gear for longer and at higher speed, so perhaps the Redex is doing it’s job.
- Axholme Lion
- Visitor
02 Sep 2021 08:07 #238151
by Axholme Lion
I thought rural fuel stations were still selling E5 but i got to my local station this morning and it was E10 or nothing! i ended up going the long and winding road to work past a Shell station where i filled up with Vpower at £1.50 per litre! I'm sure this is a Government scam to ruin all of the petrol cars over the next few years so everyone goes electric.
- Thank you received: 600
02 Sep 2021 08:10 #238152
by facade
Replied by facade on topic E10 petrol
Esso Synergy Supreme 99 is ethanol free (except in Devon, Cornwall, North Wales, North England and Scotland). It is a lot more expensive, but as I'm doing virtually zero mileage, it isn't going to separate in the tank.
- Thank you received: 1797
02 Sep 2021 15:28 #238162
Replied by Lambert on topic E10 petrol
Sorry am I missing something here? Jimny run just fine on e10 fuel. Mine even has a sticker inside the fuel flap saying to use it.
03 Sep 2021 06:48 #238174
by Busta
Replied by Busta on topic E10 petrol
I predict that every single engine fault in the next 3 months will be blamed on the 5% increase in the amount of ethanol in the petrol.
03 Sep 2021 07:00 #238175
Replied by mlines on topic Re:E10 petrol
It's been in wide use in a number of countries for a good few years
Sent from my motorola using Tapatalk
03 Sep 2021 10:53 #238179
by facade
Replied by facade on topic Re:E10 petrol
In The Olden Days my father used to run our Rover 90 on Cleveland Discol, which was adulterated with ethanol- as an octane booster.
Never caused any problem (cars were made properly then, with lead and proper rubber from the colonies), except I do recall breaking down on the way to Aberystwyth with fuel pump failure......
I'm not bothered by running on e10, just by what happens when it stands in the fuel tank for weeks on end.
You can remove the ethanol, by sloshing in a bit of water, then using a separating funnel to run the water/ethanol off from under the petrol, but I suspect the novelty wears off after the second gallon.
29 Oct 2021 23:22 #239735
by Mr CC
Replied by Mr CC on topic E10 petrol
just looked in my manual for 2001 it quotes "blends of unleaded petrol and ethanol (grain alcohol), also known as gasohol, are commercially available in some areas. Blends of this type may be used in your vehicle if they are no more than 10% ethanol. Be sure this petrol- ethanol blend has octane ratings no lower than those recommended for petrol" so this makes my jimny suitable for E10. Pretty well pleased after worrying that the restoration might be short lived.
