BigJimnyMeet 2024
Big trouble with 2020 Jimny
- Thank you received: 1759
24 May 2021 17:54 #235324
Replied by Lambert on topic Big trouble with 2020 Jimny
Is this also relevant to the earlier version in the gen3?
- Thank you received: 475
24 May 2021 19:00 #235325
Replied by Soeley on topic Big trouble with 2020 Jimny
Just a thought, could too high a tyre pressure make it worse? Tyres bouncing on the surface too much and not conforming to the undulations?
19,000 miles in my Gen4 and not had this issue.
- Thank you received: 79
24 May 2021 19:21 #235330
by Foxtrot
Replied by Foxtrot on topic Big trouble with 2020 Jimny
Is it the same problem as in this video? I once had a 2003 GEN3 with an overzealous ABS which used to kick in when braking on uneven ground or man holes.
- GeorgeC
- Visitor
24 May 2021 19:31 #235331
by GeorgeC
Replied by GeorgeC on topic Big trouble with 2020 Jimny
I had similar problem with my 2019 Gen4 when exiting the local Coles Car Park:
A big gum tree next to the driveway, it's shadow across drive in front of the Jimny, it would almost stop the car, adding much confusion to the car behind.
As for tyre pressures, I found 23psi to be the best for me with no load.
I have since returned the car (other issues) and bought a Volvo!
- Parsnip Pete
- Visitor
24 May 2021 21:47 #235336
by Parsnip Pete
Replied by Parsnip Pete on topic Big trouble with 2020 Jimny
Yes, that is what it is doing. Thankfully guard rails do not trigger it in wifes vehicle, but it has a real hair trigger for bumps on bitumen. The vehicle is a manual and has been fitted with AT tyres. It was doing it with the standard tyres as well.
Thgnks for all the replies.
25 May 2021 09:40 #235346
by saxj
Replied by saxj on topic Big trouble with 2020 Jimny
ESP can be turned off, but it reactivates at 30kph (+-18mph).
I would check tyre pressures. After market shocks should also improve the situation.
- Thank you received: 167
25 May 2021 10:17 #235350
by 300bhpton
Replied by 300bhpton on topic Big trouble with 2020 Jimny
2wd is fine (or should be), it isn't high speed and just a bit of float/movement on the stubble. But not excessive.300bhpton.
Just to even things up.
If you are getting wheel spin in 2WD , maybe you should be in 4WD!
Roger
- Roger Fairclough
- Thank you received: 194
25 May 2021 10:40 #235351
by Roger Fairclough
Replied by Roger Fairclough on topic Big trouble with 2020 Jimny
Sorry to harp on about this but using 4 wheel drive effectively halves the load on each axle and in low range reduces the load on the clutch.
Roger
Roger
25 May 2021 10:44 #235352
by 300bhpton
Halfshafts maybe, although 4 wheels not spinning might be more stress than 2 wheels lightly spinning. Anyhow my Series 3 Land Rover was 100% fine in 2wd in the fields and it becomes a pita and a pain if you are buzzing in and out of fields and onto roads to have to keep switching to 4wd. Especially when you have tractors and Land Rovers infront/behind you that don't need too.
It also stops you having a bit of fun, where some wheelspin and sliding is perfectly safe.
Not sure how it reduces load on the clutch?Sorry to harp on about this but using 4 wheel drive effectively halves the load on each axle and in low range reduces the load on the clutch.
Roger
25 May 2021 11:37 - 25 May 2021 11:38 #235356
by 300bhpton
It should be possible to diagnose if it is, such as be further away from the road edge or see if it happens in both directions.
Also, do you have buttons 6 & 7? Might be worth turning them off one at a time and seeing if it changes the results.
Having just watched the video that is something different. It isn't the ABS or the road surface, not even the ESP. It is the collision avoidance system. Not sure if this is what the Autocar article also talked about or not. Or even if this is what the op is experiencing.Is it the same problem as in this video? I once had a 2003 GEN3 with an overzealous ABS which used to kick in when braking on uneven ground or man holes.
Last edit: 25 May 2021 11:38 by 300bhpton.
- Roger Fairclough
25 May 2021 12:20 #235358
by Roger Fairclough
Button 7, the lane departure warning can be switched off permanently.
Button 6, The dual sensor brake support can be deactivated each time you start up but reverts to off when you switch off.
Roger
Roger
- Roger Fairclough
25 May 2021 12:27 #235359
by Roger Fairclough
300bhpton.
Imagine trying to start off in 3rd gear. Yes it's possible but the time the clutch is slipping is a lot longer than starting in first and this generates heat and excess wear.
Now try it in 1st gear low range and you will note the shorter length of time the clutch is slipping. Less slip less wear.
Roger
Roger
Time to create page: 0.189 seconds
