Big trouble with 2020 Jimny
24 May 2021 17:54 #235324 by Lambert
Replied by Lambert on topic Big trouble with 2020 Jimny
Is this also relevant to the earlier version in the gen3?
24 May 2021 19:00 #235325 by Soeley
Replied by Soeley on topic Big trouble with 2020 Jimny
Just a thought, could too high a tyre pressure make it worse? Tyres bouncing on the surface too much and not conforming to the undulations?
19,000 miles in my Gen4 and not had this issue.
  • Foxtrot
24 May 2021 19:21 #235330 by Foxtrot
Replied by Foxtrot on topic Big trouble with 2020 Jimny
Is it the same problem as in this video? I once had a 2003  GEN3 with an overzealous ABS which used to kick in when braking on uneven ground or man holes.
  • GeorgeC
24 May 2021 19:31 #235331 by GeorgeC
Replied by GeorgeC on topic Big trouble with 2020 Jimny
I had similar problem with my 2019 Gen4 when exiting the local Coles Car Park:
A big gum tree next to the driveway, it's shadow across drive in front of the Jimny, it would almost stop the car, adding much confusion to the car behind.
As for tyre pressures, I found 23psi to be the best for me with no load.
I have since returned the car (other issues) and bought a Volvo!
  • Parsnip Pete
24 May 2021 21:47 #235336 by Parsnip Pete
Replied by Parsnip Pete on topic Big trouble with 2020 Jimny
Yes, that is what it is doing. Thankfully guard rails do not trigger it in wifes vehicle, but it has a real hair trigger for bumps on bitumen. The vehicle is a manual and has been fitted with AT tyres. It was doing it with the standard tyres as well.
Thgnks for all the replies.
25 May 2021 09:40 #235346 by saxj
Replied by saxj on topic Big trouble with 2020 Jimny
ESP can be turned off, but it reactivates at 30kph (+-18mph).
I would check tyre pressures. After market shocks should also improve the situation.
Time to create page: 0.223 seconds
