Re:Parking on full lock
- Thank you received: 71
On the Land Rover forum it's recommended as more secure to park that way as it makes it harder to tow the vehicle away or winch on to a flatbed.
l am not particularly concerned about the Jimny as it seems no more likely to get stolen than any other car.
But if it's OK to leave it parked on full lock, then l may as well do it.
On some cars it's not recommended as it can damage the power steering pump.
- Thank you received: 552
To back this up my G3 is parked most nights at 80% full lock as was my Scimitar, simply due to the shape of my yard and I don't straighten the wheels when I park.
- Thank you received: 333
If someone wants to steel an old landy or a jimny the steering lock would probably not be a problem for even the very stupid theifs.
(more of a psychiatry problem involved for the thief here. )
No professional towing service would have any problems removing a car on full steering lock, you will only make the risk of damage to your car bigger.
And why make problems for the tow service?
It is just a guy trying to make a living removing cars parked at fire hydrants, on sidewalks, too close to zebra crossings or on your parking spot.
- Thank you received: 1761
- Thank you received: 77
lightning wrote: On some cars it's not recommended as it can damage the power steering pump.
The car is parked, the engine is off, power steering pump is not turning, not pumping fluid - how does it get damaged?
Now, I don't recall how many times I've parked and left the steering on full lock, as recommended when parking on a slope, but I do know, I've yet to damage a powersteering pump doing it.
Growling noise is most likely cavitation in the pump. Micro bursts of pressure due to trouble on the suction or pressure side of the pump or mismatch between them. No worries though. Long term use with bad oil, bad gaskets or excess heat is most likely why your pump dies one day.
Shoppers multistorey carpark Salisbury and a Reliant Scimitar = blown steering rack and bent exhausts.
Some carparks are not vintage car friendly
You may well be right, I only came to that conclusion when looking at the spring loaded valve on a car and imagining that the pressure was opening it, pressure drops, valve starts to close, pressure rises, valve starts to open etc. So i imagined it oscillating about a point.yakuza wrote: I thought that if the pressure relief valve opened, it relieves the pressure and there is no growling noise. And no pressure, no strain on anything.
I try to avoid it.
