Jimny commercial
- Thank you received: 81
17 Jul 2021 22:53 #236763
by lightning
Replied by lightning on topic Jimny commercial - driving position
Do you mean that the seat needs to be so far back that the back rest has to be straight?
How tall are you?
How tall are you?
- nogbad
17 Jul 2021 22:55 #236764
by nogbad
Replied by nogbad on topic Jimny commercial - driving position
You can remove the mess and bulkhead it's just a few bolts and problem solved, unless because it's a commercial there is some legal requirement to have it in I'm sure someone on here will have the correct information for you.
- Thank you received: 1939
18 Jul 2021 04:42 #236765
Replied by Lambert on topic Jimny commercial - driving position
The other alternative than removing the mesh looks to be turning it round so the protruding bit faces the back. Apparently it is symmetrical so should be possible.
- Roger Fairclough
- Thank you received: 218
18 Jul 2021 07:56 #236767
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Re:Jimny commercial
Is it so that Suzuki can claim a certain capacity in the rear compartment?
Roger
Roger
18 Jul 2021 08:19 #236768
The headrest hits the screen so limiting the seat angle. It does looks like the screen can be fitted slightly back, either by reversing it or by making M6 threaded spacers ( I might try that)
Sent from my moto g(
power using Tapatalk
Replied by mlines on topic Re:Re:Re:Re:Jimny commercial
Sort of. The seats are moved 10mm so that the screen can fit in. The screen actually shortens the overall rear floor space so the required volume is achieved by dropping the floor height.Roger Fairclough wrote: Is it so that Suzuki can claim a certain capacity in the rear compartment?
Roger
- Roger Fairclough
18 Jul 2021 10:59 #236774
by Roger Fairclough
Replied by Roger Fairclough on topic Re:Re:Re:Re:Jimny commercial
10mm is not a lot so maybe some work with the fixing brackets may be the answer to the lower screen and a change in the top screen angle by either riv-nuts or modification to the top mounting bracket may work.
Maybe another how to Martin?
Roger
Roger
Time to create page: 0.178 seconds
