Re:Carrying additional fuel
- Thank you received: 325
Do I need to buy a roofrack?:S
Haven't done it in the Jimny but have taken some particularly low mpg cars. The only issue I found was finding super unleaded around the west and north, not really an issue in a Jimny.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
- Thank you received: 1811
The only plus for outside is if you spill any on the fuel can when filling the inside of your vehicle does not smell of petrol, but if you are careful it's not an issue.
I have one of these which I carry (secured) inside the vehicle when needed. It's very well made and totally air tight. The down side is you need a spout which costs extra.
www.machinemart.co.uk/p/10-litre-jerry-can-2/
I simply don't like the cheap plastic cans with screw on lids, it's a personal preference thing, I had one pop off once possibly as I had not fitted it correctly in the dark.
- Jimny-Phil
- Junior Member
- Thank you received: 8
PJ
2020 Brisk Blue JB74 SZ5
I also have the 20ltr versions for my Land Rover and have had no issues filling them, I went 10ltr in the Jimny as it was a limit on the channel tunnel crossing and we went during the French fuel strike, so needed extra just in case.
- Jimny-Phil
- Junior Member
Lambert wrote: When I go I remove the plywood liner from the back and find that a metal 20l can fits nicely behind each front seat with a ratchet strap just on the off chance of a bump in the road dislodging them. It's double the standard capacity and completely removes any concerns about fuel so you can get fuel as it becomes available instead of having to planning it or worse actually having to go out of the way to find it.
What do you secure it to?
PJ
