car ramps or jack advice pls
09 Aug 2020 15:09 #226404
by Gadget
Replied by Gadget on topic car ramps or jack advice pls
The metal car ramps all seem to be of the same design, regardless of brand and I've heard stories of them suddenly folding, which was enough to put me off buying.
I went for these Sealey ramps, which aren't quite as high, but are very robust. I still place axle stands as well when I'm underneath, as I'm paranoid about getting squished!
www.amazon.co.uk/dp/B07CZFWT6Y/ref=cm_sw..._apa_i_YdbmFbY168YB8
The following user(s) said Thank You: treps
- Andy2640
09 Aug 2020 15:19 - 09 Aug 2020 15:36 #226405
by Andy2640
Replied by Andy2640 on topic car ramps or jack advice pls
It took me ages to choose the right axle stands and wheel ramps.
Some wheel ramps looked pretty lame, with no cross bar where it mattered (under the wheel). The cheapo ones all had no extra bar, so i went with these.
These have this extra support bar
The axle stands were middle of the road ones, but have decent welding and rated for 3t per stand.
Buy the best you can afford obviously.
I still get anxious underneath though, and place huge blocks of wood under the arm gaurds just incase of axle or wheel stand failure.
U cant imagine the damage and pain of getting slammed under a diff. OMG i would squeel like a piggy!!!
Last edit: 09 Aug 2020 15:36 by Lambert. Reason: Swearing. Please remember this is a family friendly forum.
- Roger Fairclough
- Thank you received: 211
09 Aug 2020 15:40 #226406
by Roger Fairclough
Replied by Roger Fairclough on topic car ramps or jack advice pls
It's all about piece of mind.When you get your ramps put them somewhere as flat as possible and strong enough to support the load. When backing up I use low range as it reduces clutch slip. You need to try this a few times to get used to positioning the car properly. Personally I don't like the design because for safety the wheels should drop into a well which stops any chance of the car rolling off the ramp. When you are satisfied that you are positioned safely get out-mind the drop-and vigourously shake the car. If it falls off:sick: try again.:whistle:
Roger
Again, for piece of mind, obtain 2 pieces of 18mm ply 250mm square and screw the stands to them. They will be far more stable.
Roger
09 Aug 2020 20:01 #226425
by treps
Replied by treps on topic car ramps or jack advice pls
@Gadget - thanks. Are these plastic ramps known to be stronger than the metal ones? I hadn't seen them before but I like the concept
- Roger Fairclough
09 Aug 2020 20:36 #226427
by Roger Fairclough
I like the ones with the "well" to drop the tyres into but note that they are lower than the metal ones. You could, if you believe you need the full height,build a base out of wood and attach to the ramp. just a thought.
Roger
Roger
09 Aug 2020 21:25 #226429
by Gadget
Not seen any categorical proof that they're 'better', but they're rated for 1.5t each, so one in isolation can hold the entire weight of the car and less chance of one dodgy weld causing a whole ramp to fold, plus Sealey are a decent quality brand, so I felt happier sliding under the car with those. They don't provide as much clearance as metal ramps, but I could fit under the Jimny without them, so the added space is just a bonus
treps wrote: @Gadget - thanks. Are these plastic ramps known to be stronger than the metal ones? I hadn't seen them before but I like the concept
Time to create page: 0.182 seconds
