car ramps or jack advice pls
08 Aug 2020 11:50 #226339 by Lambert
Having been working on cars for years I have been collecting this kit and upgrading it as I go. So with that in mind I would suggest that you avoid the cheaper options and go straight to the higher cost heavy-duty professional level kit to start with. I accept that just starting out it's quite an expensive hit but its going to be quite a lot cheaper than buying several jacks and stand. You get what you pay for. I would not be happy working under a vehicle using the kit in the link. My minimum quality level is Machine Mart for Clarke.
The following user(s) said Thank You: treps
08 Aug 2020 11:50 #226340 by treps
Replied by treps on topic car ramps or jack advice pls
Thank you gentlemen for your replies. Great advice.
I will get the ramps and chocks now. They sound the simplest and safest method.
Regarding the jack, I just saw on another thread that the Halfords Advanced 3T trolley jack is highly rated. I will get one of those in the autumn sales together with the 3T stands.
I feel all grown up...
08 Aug 2020 12:17 - 08 Aug 2020 12:20 #226344 by Scimike
+1 for the Halfords Advanced 3T jack.
I have had one of these for many years and it still works faultlessly. Quick lift and used on my Land Rover as well as the Jimny, more than enough to lift the entire Jimny if you are not watching. Lambert is correct, pay a bit extra now and it will last you years. I also use Clarke 3T stands.
Mike
Last edit: 08 Aug 2020 12:20 by Scimike.
The following user(s) said Thank You: Lambert, treps
08 Aug 2020 12:25 #226345 by Lambert
I looked at the 3t stands but went for the 6t instead. Mainly because at 600mm open they are tall enough to go under the extreme corners of the chassis and yet be tall enough to have the wheels off the ground on full droop which is super useful for suspension work and rust prevention. Also at 6t each the factor of safety with a tonne of Jimny on 4 stands makes me feel better about being under it.
08 Aug 2020 12:47 #226353 by Busta
Replied by Busta on topic car ramps or jack advice pls
Car boot sales are a great place to find ramps and axle stands. But I'd buy a trolley jack new. I've managed with cheap trolley jacks for years but last year I treated myself to a better one (it says "professional" on it so you know it must be good) and it has made life a lot easier.
Jimny's are easy to work on with plenty of sturdy places to jack from or stick an axle stand under so it's a good vehicle to start on!
08 Aug 2020 14:05 #226357 by Scimike
Lambert wrote: I looked at the 3t stands but went for the 6t instead. Mainly because at 600mm open they are tall enough to go under the extreme corners of the chassis and yet be tall enough to have the wheels off the ground on full droop which is super useful for suspension work and rust prevention. Also at 6t each the factor of safety with a tonne of Jimny on 4 stands makes me feel better about being under it.
I was in error, I also have the 6t version, can't remember why I picked these, probably due to my Land Rover.
Time to create page: 0.319 seconds
