Chinese Steel Bumpers: Installation
- Rabid Rhino
- Elite Member
- Thank you received: 32
AHTR...
2 holes on the right side dog leg bracket line up with 2 holes on the towing eye bracket.
But
There's only 1 hole on the left side dog leg bracket and it doesn't line up with anything. Did you drill any holes ?
- Thank you received: 923
Rabid Rhino wrote: Missing a load of nuts and bolts from a torn open bag as the box was quite badly damaged.
Hopefully that's all I'm missing.
1 Dog leg bracket is on the car
What are the brackets below for & where do they go ?
I had no instructions. Drilled a few holes, just made it up as I went along, few extra bolts on the 'dog leg' brackets. Also where the 'dog leg' brackets bolt to the winch plate I drilled right through the chassis legs and bolted right through with some steel/spacers to strengthen it up.
The parts you've got left I just put in the scrap bin. The 2 bits on the left bolt onto the end of the chassis rails, then the winch plate is supposed to bolt to these using the big washers you have left. But like I said, I binned them and made up something myself as the fit wasn't great.
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
- Rabid Rhino
- Elite Member
I can't get the ends to line up with the arches. I'm out by about 0.5" there and under the lights there's a similar 0.5" gap.
The bumper won"t go any further back because its hitting the front edge of the lower slam panel.
So the only solution I can see is trim 0.5" of the rear top edge of the bumper
Trim the 0.5" here
- Reason2doubt
- Thank you received: 100
No instructions on mine either. Had some bits leftover but still couldn't think of where they could go so they got binned as well.
- Reason2doubt
- Rabid Rhino
- Elite Member
Do you have a pic of the left side dog leg ? Did it mount to anything ?
Yours is nice & tight against the body, which mine isn't but I'm trying to get there.
Are you noticing my Star Wars references with your user name ?
When I bought mine I accepted they're cheap bumpers knocked out of a factory in China that probably don't have the finest build tolerances.
- Reason2doubt
Yes haha loving the star wars references with my name
- Rabid Rhino
- Elite Member
After cutting 1/2" off the back side of the front bumper top the uprights now foul the leading edge of the lower spam panel. So more cutting needed to get it back enough for the corners to fit into the wheel arches.
- Rabid Rhino
- Elite Member
The right side bracket lined up OK with the bumper but the left was out. So much so the bolts wouldn't go through.
The holes on the chassis bracket where the bumper holes overlapped were scribed.
There wasn't enough metal on the edge of the chassis bracket to extend the holes so the end plate was cut off and moved over 1/2"
So the left side finally fitted
But the right side was still out...
The reason... The corner strengthening plate for the spare carrier was hitting the corner of the body
Cut out a small piece of bumper and at last it fitted
- Rabid Rhino
- Elite Member
Quality Chinese products.
