Gen4 - Selecting 4WD
- OctaneJimny
- Premium Member
- Thank you received: 37
www.bigjimny.com/index.php/forum/8-my-ji...-ivory-manual#210539
Instagram: OctaneJimny
FB: Suzuki Jimny 4th gen (JB64 JB74) owners club
- Andy2640
- Visitor
Scimike wrote: I have no idea, but let's look at the clues as they say.
I believe the front hubs are the same as a G3, ie vacuum operated. The transfer box is lever operated, the G3 transfer box is solenoid operated, its no more than an electrical lever, so can't see much difference here.
You can happily bang in and out of 4WD high on a G3 without using the clutch, the manual indicates you can do this up to some (cant recall) high mph figure. You only need to stop and preselect foot and steering wheel positions (ref manual) for 4wD low.
So I would guess the G4 is the same, but would have expected it to declare the same MPH limit and preselection details in the handbook as it does for the G3.
Also Andy's done it and it works
Having said all that I always try and stop if I can. Selected once 4WD Hi while traveling at 35 ish mph, the bang from the front hubs as they engaged went right over my mechanical sympathy level.
But yes, good question.
Mike
Good to know my comments and opinions are taken seriously!
- Thank you received: 1761
- Thank you received: 95
Daniel30 wrote: thought it was the same as a gen3 but the leaver connects the micro switch instead of a button on the dash, the lever is there for the more classic/ retro look
The lever may just an alternative way of connecting an electrical switch action for 2WD to 4WD but it seems to be more of a mechanical switch when it comes to selecting Low Range/High Range? Haven't had the time to visually check the underside and I'm not curious enough to go out and crawl about in the slush and snow.
- Thank you received: 584
Dipping the clutch helps the back wheels roll at the same speed as the front, but the stationary diff and propshaft still have to accelerate to road speed on the synchro cone between the front output shaft and the main output shaft in the transfer, so I'd keep the speed down rather than go for it at 60.
- Andy2640
- Visitor
facade wrote: The reason to dip the clutch is because if the back wheels are spinning at 60mph but the fronts aren't moving and you snatch 4x4, likely the teeth will come off something.
Im not sure about this. So accelerating slightly is a big no no in this case then, as this will be giving the rear wheels and prop etc more of a challenge for the front to sync too??
The only time I've ever made it bang was messing around in the mud, 2wd low, sliding backwards with the wheels spinning forwards and then flicking my 2 low switch into 4wd, making the hubs engage the stationary front wheels to the rapidly rotating front driveshafts. But that's not a situation that's normal or easy to repeat!
Only significant if the back wheels are spinning. I think the manual is translated wrong. The average non-mechanically sympathetic driver interprets all controls as fully on or fully off, so lifting up slightly would be a better instruction than stamping down.
If you aren't frantically spinning the wheels the system will cope. If you want it to last longer, keep the speed down. Dippng the clutch is easy on a manual, you treat is as a gearchange.
- Thank you received: 168
Shifting from 2H to 4H is essentially shift on the fly rated to 60mph. To do this you need the wheels point straight (because the would be spinning at different speeds left to right if you are turning) and have the front and rear wheels moving at the same speed. Ie not wheel spinning. Revs are required for the vacuum operation of the front hubs. But no need to use the clutch or shift into neutral.
Obviously shifting at low speed or stationary is less risky of accidentally shocking the system, there is less potential energy involved. And trying not to shift when wheelspinning.
Shifting to low is different because you are actually swapping ratios in the transfer box. For this you’ll want to be in neutral and/or put your foot on the clutch. Stationary is probably best, but suspect rolling at walking pace and it’ll probably still be ok.
- Andy2640
- Visitor
300bhpton wrote: So I read the manual for my new Jimny last night.
Complete standstill/stopped for transfer to 4H to 4L. I think that a hard n fast rule to be honest mate.
Andy2640 wrote:
Going down to low is hard to do whilst moving but shifting back up to high can easily be done on the move if you have a little mechanical aptitude. I haven't had any issues arise after doing it almost daily for the past 6 years.300bhpton wrote: So I read the manual for my new Jimny last night.
