BigJimnyMeet 2024
Re:Tyre Pressure for 215/75/R15 ?
- B3Hulk
- Visitor
26 Jan 2020 07:44 - 26 Jan 2020 07:45 #217694
by B3Hulk
Tyre Pressure for 215/75/R15 ? was created by B3Hulk
Hi All ,
There has been so many threads about tyres but not much about tyre pressure. If there is a thread that has this answer, please direct me to it.
I have recently bought some new steel wheels - 15x7" with 13 negative offset.
I am looking to add on them some BFG KO2 215/75/R15's but I don't know what PSI should I have.
Does anyone have a good idea on what tyre pressure would be best for :
Any useful suggestions on what PSI I should be running on any scenario would be helpful!
Also , has anyone had any rub issues with such a large negative offset?
- Touring/ Everyday - ___ ? (possibly 30 PSI
- Sand - 13-16 PSI
- Mud/Rock - 20-22 PSI
Last edit: 26 Jan 2020 07:45 by B3Hulk.
26 Jan 2020 08:04 #217695
Replied by mlines on topic Re:Tyre Pressure for 215/75/R15 ?
23 front , 26 rear
Drop 3 psi off-road if you want
The following user(s) said Thank You: gusthegorilla, B3Hulk
- Thank you received: 1761
26 Jan 2020 10:46 #217698
Replied by Lambert on topic Re:Tyre Pressure for 215/75/R15 ?
Negative 13 is barely anything. Standard is between 0 and negative 5 depending on which steels or alloys you have. Negative 32 is a fairly common size instead of using spacers and it's not usually a problem especially if you don't have front mud flaps.
The following user(s) said Thank You: B3Hulk
- Thank you received: 305
26 Jan 2020 11:57 - 26 Jan 2020 12:02 #217700
by sniper
Replied by sniper on topic Tyre Pressure for 215/75/R15 ?
I run KO2's in the same size. 24 psi all-round is where I am at.
I have tried a number of pressures and different front to back..... 24 psi works for me and my driving style. I drive fast B roads mainly and want a relatively stiff sidewall allowing fast changes in direction without the wallow caused by soft sidewalls.
I do plenty of off roading (rock, mud, sand) and have never had to lower pressures to get out of trouble. The day may come...... I would happily lower to 10psi if needed, the tyres would stay on the rims.
I run 30mm spacers and have no rubbing issues with a 45mm lift. There was no rubbing on standard wheels and standard suspension. Offset wheels and 215's on old tired suspension will rub on full lock, not much tho.
Cracking tyres in my humble opinion.
sniper
sniper
Last edit: 26 Jan 2020 12:02 by sniper.
- B3Hulk
- Visitor
26 Jan 2020 23:00 #217720
by B3Hulk
Replied by B3Hulk on topic Tyre Pressure for 215/75/R15 ?
Thanks all for the advice , very useful.
I have the Gen 4 Jimny 2019 , would that make any difference in PSI ?
27 Jan 2020 03:53 #217724
26 all round in Gen4
27 Jan 2020 05:04 - 24 Oct 2022 17:29 #217725
As it's a gen4 the offset of the factory wheels is actually negative 22,( actually we now know that all 3 and 4 wheels are et5 and interchangeable) so with a negative 13 rim you're moving the wheel inboard 9mm which could be ok but might actually cause rubbing when at full steering lock or compression. Are you firm on having a complete second set of wheels and tyres because the 215s will fit the factory wheels and you would have one less complication.
Last edit: 24 Oct 2022 17:29 by Lambert.
29 Jan 2020 18:27 #217820
by Busta
Replied by Busta on topic Tyre Pressure for 215/75/R15 ?
I run 215/75 r15 BFG Muds.
I run them at 21psi on the road.
16-19psi off-road.
As low as 10psi on soft peaty ground or sand.
As a rule of thumb, the larger the volume of the tyre, the lower the pressure. Fitting bigger tyres and running them at higher pressures than standard is a recipe for a slipped disc!
16-19psi off-road.
- B3Hulk
- Visitor
30 Jan 2020 05:04 #217828
by B3Hulk
Thanks everyone for replying.
Once I get the KO2's on the Gen 4 Jimny, I will play around with the tyre pressure.
I was thinking between 20-24 psi and looks like that is the what everyone is generally doing.
I have contacted BFG and waiting for their thoughts as well.
30 Jan 2020 05:28 #217831
Replied by Lambert on topic Tyre Pressure for 215/75/R15 ?
It is possible to calculate the exact number using the information on the sidewall of the tyre. It will state the maximum load the tyre can support at the maximum pressure it can contain. Therefore with the maximum axle weight of the car from the vin plate it is simply a matter of working that back into the pressure the tyre needs to support the load the car imposes.
- B3Hulk
- Visitor
13 Feb 2020 05:39 - 13 Feb 2020 05:42 #218419
by B3Hulk
Last edit: 13 Feb 2020 05:42 by B3Hulk.
13 Feb 2020 06:12 #218422
Does this account for the weight of the Jimny as in did you give them the axle weights as well as the inflation pressure of the standard tyres because those pressures seem a bit high for a tyre with a load index of 100? Not saying that it is wrong just seems a bit arbitrary.
Time to create page: 0.150 seconds
